Root bales....sorta
tony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Topic: Root bales....sorta
    Posted: 27 Sep 2017 at 6:41pm
Have a young lady that will be showing some of our cattle next year and so we need some small bales to take to shows. I only have a round baler's and wondered if I could make some Roto bale sized bales to fill this need.
Set the baler to make as small a bale possible. Ended up with bales that are about 2-1/2' in diameter x 4' wide @ 150 lbs or so. Little bigger than I'd like so now I'm looking for a way to slice(crossways) them into smaller pieces. Anybody have any ideas? I was thinking maybe a machete?
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2017 at 7:41pm
You can rip a Roto bale with a chainsaw, I never tried to cross cut one.
WD45 Diesel, RC,CA,IB, B, G, 616, Early B-10, D-10, Terra Tiger, 95G spreader, SC blade
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2017 at 7:53pm
Chopping ax.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2017 at 7:57pm
maybe trade your round bales for someone else's small square bales ??
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2017 at 8:39pm
you can use a chain saw but It will dull the saw really fast,, two man cross cut will work also,, or any kind of log sawer type saw..
I chopped up a big round bale for my granddad years ago for his sheep,,, dulled the chainsaw really fast
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2017 at 8:52pm
They make pine straw balers that make small rounds now. I think they're a little smaller then bales from a roto baler but about the same. If I remember right they're pretty pricey too but it is an option
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 6:34am
Two guys with a piece of barbed wire can cut a bale nicely. Use a piec of broom stick on the ends for a handle and pull it through like a bow saw. I've done it to slice 5x6 bales into slices. I had tried a chain saw first but don't do it. Taking the chain saw apart to clean it out was a pain.
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 6:40am
On the farm we had a "bale saw" or hay saw... however I never remember actually using it cause we did not need to make smaller portions...i just googled hay saw, and that is what it looked like.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 6:58am
Not that it would work for your situation, but back in the old days we used a hay knife to slice the roto bales down the middle to feed to dairy cattle.  It's been a while but it worked quite well to feed the bales out in halves rather than  whole ones.  I don't remember what we did about the twine.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 7:51am
Buy a Roto baler. Roll out the big rounds, and roll em up with the roto baler. Darrel
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 10:56am
Oat straw or wheat straw? Horsemen generally use wheat straw because of its more golden color. FWIW you would probably have less of a headache if you just bought a few bales of the stuff.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 11:33am
here is a hay knife.
 I have used one like it to cut round bales open on one side so they laid out and then carried the layers in by fork, or rolling a layer up and just dragged it in. All is work, easier to just buy a bunch of small Squares and be done with it.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 11:43am
x2!
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 2:04pm
Don't it say he has a roto baler? A hay knife like pictured above will do the job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2017 at 7:34am
No Tom, he states:
"I only have a round baler's and wondered if I could make some Roto bale sized bales to fill this need."
He has a round baler, but not a roto-baler.
Tony, isn't there someone on your side of the state that has a roto-baler?  You could trade or buy some bales off someone over there.
This page was generated in 0.062 seconds.
