7G
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: 7G
    Posted: 25 Sep 2017 at 2:14pm
My old 7G turbocharger is getting close to change out time. Loads of erosion noted on exhaust side while repairing the exhaust. Have noted is listed as a Air Research T04, but are sub sets as 055 or B80. Will the T04 B80 series for the 7000 series engines interchange to the manifold on my 7G? It does have the old style I believe T04 055 on it. Steiners has new ones for 365 and change.
I need to rebuild the exhaust 90 as well try to reconfigure to return to the hood mount stack not on engine. Replacing the turbo at the same time makes sense.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2017 at 9:35am
Brake fluid finally dissolved the paint on the tag. No one seems to be able to cross:
Air Research T0448 P/N 408270-3 Allis p/n (7)4023985
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2017 at 9:38am
I can check the tag on my 145T grader with 7000 engine if it might help
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2017 at 12:54pm
thanks
I am thinking all the 7000 4 cyl engines were same configuration.
Edited by DMiller - 26 Sep 2017 at 12:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2017 at 1:25pm
pretty sure mine doesn't have that goofy pedestal just a curved pipe that exits into the hood mounted pipe
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2017 at 1:31pm
Am pretty certain mine is a 'Custom' job, not much appears as factory on it.
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2017 at 4:36pm
TO4 is the size designation so any TO4 will fit. There are different turbine and compressor parts that effect performance. The important feature is the A/R values. A = area R = radius You can measure these along with a picture of the impellers a turbocharger supplier can fix you up with something pretty close. My HD6G has a turbocharger that was specked for a 355 Chevy V8
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2017 at 7:08pm
Can get a T04B80 from Steiners, supposed to fit the 7000 engine but none of the numbers relate. Is a will fit for 190, D21 and others ACS3681 p/n
https://www.steinertractor.com/ACS3681Turbo-Charger-w-Mounting-Gasket-NEW-not-rebuilt
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2017 at 12:08pm
If I remember right the 7g we had was a Thompson . we got it from john deere about half the price the A/C F/A dealer wanted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2017 at 12:46pm
Mine is the original, wish I had a response back from Honeywell Garrett, but they seem to not care. Just trying to validate the one Steiner has will function correct as can get. Steiner's people do not think so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2017 at 12:52pm
my apologies.  did not make it to the grader last night.  had a honey doo list when I got home and the blade is over at my brothers place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2017 at 2:55pm
Totally OK, is not as if I need to change it all that soon, just looking ahead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2017 at 4:26pm
Well was reported back from Diesel Fuel injection of Louisville the T04B is a direct replacement A/R wise and mounting. The unit that goes on the D19, the 200, most of the 7000 series was a T04B. Any images of these mounted to engines?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2017 at 9:20am
I could get a few pics of one mounted on a D19 manifold but is off engine currently we are rebuilding.  would be this evening if you don't get something first
david weldon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote david weldon Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 3:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote david weldon Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 3:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote david weldon Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 3:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote david weldon Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 3:43pm
hello dave if these are any help to you this is my allis chalmers HD7G S/N 23020  I think its year 62/64 not sure maybe you can correct this for me ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 5:13pm
That is what mine is supposed to look like! Mine is one of the last 74-76 but has the same aspirator design on the square air cleaner at the operator station. All but eliminated on mine as well. Currently no one responding to parts requests on the exhaust in the states. Hector has parts off a G-B but won't cross to mine. Thanks Dave.
Edited by DMiller - 09 Oct 2017 at 5:15pm
