WD serial number research
Greg061 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg061 Quote  Post ReplyReply Direct Link To This Post Topic: WD serial number research
    Posted: 23 Sep 2017 at 11:09pm
I recently purchased another WD with the intent to use as a parts tractor. To my suprise I found that the serial number is very low! As in one of the first off of the line. Is there somewhere that I can find detailed info on when and where the tractor was sold, etc. All I have been able to find is the year. Thanks!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2017 at 4:09am
Numbers 32 and 45 are in the 'Owner Registry'
Gary
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2017 at 6:31am
What is the number of your tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2017 at 8:13am
Originally posted by Greg061Is there somewhere that I can find detailed info on when and where the tractor was sold, etc. [/QUOTE Greg061Is there somewhere that I can find detailed info on when and where the tractor was sold, etc. [/QUOTE wrote:
In a word, NO Cry
In a word, NO Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg061 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2017 at 1:27pm
Thanks I checked out the registry. It's disappointing to hear that there's no historical information out there on these tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2017 at 4:04pm
Greg I would keep it as it may be the earliest WD left. I used to own RC 8 and sold it for a good amount becuz of the low number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg061 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2017 at 4:21pm
The stamp on the engine block where the engine serial number is shows WD 345. No KA or PA after and is way off from any engine serial number I can find.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2017 at 7:00pm
Greg, does it look like the rest of the number wasn't stamped or was ground off? Check this page out http://wsmth.people.clemson.edu/SNFind/esn_tsn5.htm WD engine numbers start in the 200xxx range. It's possible you have a very late WD instead with an engine number of 345xxx. Can't always date a tractor by the engine block as it may have been changed anyway. Find the tractor no. on the back left side of the differential or on top along the edge by the left brake cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg061 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2017 at 7:34pm
Bill
I have the tractor serial number and I was trying to see if the engine was origional to the tractor. The engine serial number does not appear to have been ground at all. I guess its possible it wasnt stamped. It has the shorter head, which to my understanding is the older engine. Of course the head could have been changed at some point also.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2017 at 7:42pm
So what is the tractor #?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg061 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2017 at 8:17pm
WD13
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2017 at 8:58pm
A lot of that information wound up in dumpsters when the Germans invaded.
