WD wide front/Narrow steering parts
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Topic: WD wide front/Narrow steering parts
    Posted: 22 Sep 2017 at 2:45pm
Could anybody advise me if the steering mechanism (worm, bearings, major interior parts) are the same on a narrow front WD and a 4 bolt wide front WD45? I have a wide front that keeps getting locked up and difficult to turn and a spare narrow front end from a WD. Would like to keep the 45 a wide front and thinking of swapping some parts but hate to tear into it and find out I was making a bad assumption.
Thanks
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 3:18pm
I just checked the agcopartsbooks and the worm gear is same # but the sector gear on the vertical shaft is different #  for each
if you want to look into it further
Edited by CAL(KS) - 22 Sep 2017 at 3:22pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 3:55pm
Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 6:27pm
Call Sandy Lake and talk to there tech guy. As said, a few parts may be interchangeable???
But this sounds like it needs to be taken care of anyway so might as well take the wide front apart enough to see what the problem is. I assume you have checked the steering "U" joint?
Maybe jack it up a little and see what the issue is?
Pictures are always good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 10:00pm
Make sure a pin in ujoint is not coming out catching oil pan or block.   MACK
