What y'all make of this situation
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: What y'all make of this situation
    Posted: 20 Sep 2017 at 8:29am
Years ago when I moved down here to Hebron to farm, I started running Cenex oil in everything. When it come to my gas tractors, the Cenex manager in town thought straight 30 weight auto gold was what I should use. I reluctantly used it, but after running it with no ill effects I continued to do so. All of my GAS tractors have it in them, and use little to no oil.......until now. About a month ago, I changed oil in my D19 and in my one ninety gas, and put in the 30 weight auto gold, like they've had in them for years, and all of a sudden both are taking a quart of oil every 2 to 3 hours. One is running a PTO generator on a pasture well, and the other raking hay. Not heavy loads by no means. I talked to the cenex manager, and he said to change it out and put some 518 in em and see what happens. Guess I'll try that. I'm kind of sick to my stomach about the whole deal. What could have went wrong? Darrel
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 10:01am
Could be coincidence or maybe they changed the oil formulation?  I doubt that you will ever know for sure.  It's a bum deal for sure.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 10:52am
And you are not using a multi-viscosity oil that "adjusts to the temperature" because ???
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 11:46am
UG  a bum deal for sure.  Good luck finding a kit for either engine! Dead
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 11:54am
I have used the Cenex oil for years in both gas and diesel. I use mainly 15-40 in the diesels which are a duramax with 145000 miles and my D21 neither use oil. My D17 I use 10-30 in and it uses oil and always has needs overhaul but dont use it all that much so am not going to do that. If I was you I would change to a 10-30 or 10-40 and try that. You can have a sample sent in to Cenex for a test to see if there is a break down of oilo or metal in the oil they do that around here for no charge and are happy to do it. Hope this helps you Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 12:05pm
I don't understand the oil usage, but using a STRAIGHT weight oil in a motor these days is abuse..... Might work in summer, but 30 weight is WAY TO THICK to startup a motor in the winter months......... Look on you-tube at what 30 wt oil looks like at 10-20 degrees ambient.  You should have been using a 10W-xx  or 15W-xx motor oil from the beginning......Assume usage is burning due to cylinder/ ring wear or valve stem / guide wear .......... both might have had better luck in the winter with a 10w -30.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 12:19pm
If the engines are damaged and now using oil (which is a bit of a premature conclusion granted) how is switching to a multi viscosity NOW going to help?  If he'd used multi visc all along, it would have prevented wear at startup, especially in the cold, but always really.
My guess is, both engines are damaged, and it's a freaky coincidence they are showing up at the same time like this....I hope I'm wrong or it's not too serious.  Good luck.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 1:28pm
I didn't see where Darrel said he was using the tractors in the cold winter months.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 1:38pm
Yeah, not currently anyway.
Actually, I for one didn't really mean my post to sound like that.  Multi visc helps on start up wear (cold as far as the engine is concerned), and it sounded like he's been doing this for quite a while, maybe not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 1:57pm
The book will say to use 10 weight in the winter, and 30 in the summer. I realize that multi viscosities were not perfected at the time the books were written. BTW, it is summer time now. Some folks will tell you to use multi viscosity now; others will say stick to the straight weights. As posted, I've been using this straight weights for quite a few years now, and with good luck, as stated. The D19 does not get started in the winter time at all. The one ninety sometimes, but always plugged in prior to starting. All of my diesel motors get cenex super lube, 10-30 for winter; 15-40 in the summer. I've had good luck with that as well. I'm not condemning cenex oil, I just think think there may be some kind of a fluke here. Don't really know. Darrel
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 7:17pm
Never heard of Cenex oil is it some kind of supposed super oil like Amsoil?
BTW I use Kendall diesel grade 15W-30 in every engine I own and never have had
a problem that was oil related I know of.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 7:54pm
Thinks you need to tighten up your drain plug... or the filters... Shocked  LOL
 Hope something that simple.,
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 9:18pm
I'm with Stan IL&Tn. They will never tell you they changed suppliers. MACK
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 9:55pm
First of all, sorry this chizzle is happening to you.
i know you and the boy and the whole family have had a tough spring, summer.
Second, this just seems too much of a coinkadink to me. Two tractors previously running just fine, drop oil, change filter, new oil, same brand and weight, and, burning oil...a lot of oil.
I would not change oil on anything else with the stuff you have in stock right now. If you have any new oil left of the stuff, I wonder if it could be analysed. Its just hard to believe that these conditions could develop in two engines simultaneously and so quickly...Glazed cylinders causing a blow by condition? I guess you could stick a scope in each cyl and see if there is any harring bone left, or if they are glazed up, or scored up.
Otherwise, I think I would pull the pans, have a look see...Id check some bearing clearances, you can then see what the bearing material and the crank are looking like and what if anything is in the bottom of the pan. If that doesnt seem to get to the problem, I guess I'd have to take the head off, see what was happening there and on  the valve train...Time to check valve clearance?  Id run the tractor without the valve cover on and see how much oil is getting up there...If for some reason there is a bunch of oil getting to the top end, drowning it a bit, as a result of the new oil and filter cleaning passageways better...?But both wear out and start burning oil at the same time? I didnt watch every season of Matlock for nuthin...sumthin is up here...
As far as the rest of it goes, I'm not gonna tell ya what oil to use, not the question you asked...
I present these ideas as they all have some basis in my experience. For example a neighbor had a 4440. He had changed oil/filter with the JD genuine stuff. The tractor, which was not new, began to burn oil, but did not seem to lose much if any power. The owner was a solid, long term JD man, started with a D. They sent a salesman out to tell the man that the cyls were glazed, he needed to pull it harder. He indicated he was pulling a 32 foot deep tillage cultivator/chisel plow with 145hp rated two wheel drive on 20.8-38s and weight/calcium... They ended up taking his tractor to town and "rebuilding" it. I think they took it apart and honed it, put it back together. Or maybe they gave it the Ajax treatment and it quit smokeing...
Sorry for the long post, take care.
HTH, Trev.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 10:13pm
"Never heard of Cenex oil is it some kind of supposed super oil like Amsoil?"
Cenex is a brand name, origin was Farmers Union Cooperative.   CENtral EXchange. Have their own refinery in Minnesota.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 6:09am
I hope the manager or representative supports  your investigations.  It is a hell of a coincidence.  I hope they support you and you figure it out and it isn't too bad.  Good luck.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 7:32am
I would stop running them now.
Then service one with Shell Rotella and see what happens.  There is something amiss here.
Just what I would do on the oil, use something else but change one out and run it.
I run 15W40 even in my little three jug yanmar and it is very happy with it.  Never add any.
What a bummer.  An update down the rod would be educational.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 7:55am
A story about Rotella T.A friend of mine runs several big trucks couple dozers,trackhoe
etc.He had always run the Kendall 15W-40 diesel grade oil,but he got a good price on a
large quantity of Rotella T 15W-40.First truck he tried it in was a dump truck, that morning the driver calls back and says the truck has lost oil pressure.So my friend gets a filter and the Kendall oil he'd been using goes down and changes the oil back to Kendall in the dump truck on the side of the road.Fires the truck up oil pressure is back and ran fine after that.
As he said he's not real sure what happened but he'll never use the Rotella T again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 8:07am
I am definitely going to put something different in, and see what happens. I'll go to my grave swearing that there was something wrong with that lot of oil. A little guy like me doesn't have a snowballs chance in hell of getting anywhere with cenex as far as any retribution. But like I stated above, the super lube that I run in my diesel engines is top notch. Brother in law bought an L2 about 10 years ago from a neighbor. Got it cheap, because the neighbor said it would burn a gallon of oil in a long day, and he had been using the same chevron oil in it as the owner prior to him had been using in it. We switched it to cenex super lube, and never added another drop of oil to it. Darrel
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 8:53am
Just   a   thought   from  days gone  by
Have we forgotten  the experience of  when high detergent oil  was introduced  and what happened to the old  motors that had run  their  lives on  30 weight  non detergent ?   my 53  plymouth that did not burn  oil  sucked oil like an alcoholic  after my service station  manager said now  is  the time  to switch to  10w - 30,   my  guesss is   away went  all the sludge  that  plugged all the leaks .
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 9:06am
Or... dissolved the sludge and now it's being circulated; tearing things up.
Sludge in a non-detergent engine is some nasty stuff.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 9:33am
I don't think sludge was the issue. The CENEX rep obviously was not qualified to make any recommendations about which oil to use. I doubt he bothered to open the owner's manual and check the manufacturer's recommendation.  Alas there are so many of those shade tree 'experts' floating around who represent themselves as the last word - knowing more than the manufacturer. Then again the oil may have had nothing to do with the failure. The engines may have reached the end cycle of their life.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 11:34am
If you are going to do oil samples I would send them some where else besides cenex, if there is a problem with the oil not always sure you would find out about it.
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 9:12pm
I would recommend Blackstone Labs in Fort Wayne,Indiana. They will send you a kit for free to mail the sample to them. I used them to find out what I was dealing with on my 175 before I rebuilt the pump and injectors. They furnish very thorough and precise test results. Test cost me $27 and was worth it if just to find out that there wasn't any anti-freeze/water in the sample. Good luck.
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 9:32pm
Darrel, get a oil sample bottle from Butler Machinery, should be under 20 buck's.
 Top notch oil lab.
More than I need
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 9:34pm
We have been using Rotella T in our diesels since I can remember. Never had any issues, My guess is he had a bad filter on the dump truck, I had that happen to me in a Chevy Astro van. Changed the oil with the same oil but a different brand filter. Oil change special came with a free Fram oil filte. Big mistake, only 15 lbs pressure on start up. Removed it, put a new AC Delco filter on it the next day. Solved my problem. They sent the filter to Fram and promised to get back to me. Guess what, never got a call. I to hope the manufacture is honest with your samples.
Back to the origional post my guess would be as others have said, formula change or a flaw in production possibly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 8:37am
I have never heard of Cenex motor oil either, but I'm on the other side of the country here in New Joisey. Kinda strange though that two engines all of a sudden started using oil. I've always run Cam 2 10w40 or 15w40 in all my Tractors and equipment and never had a problem so far. I have seen engines use oil if they were originally on straight weight oil then switched over to multi-grade. The multi-grade does a good cleanup job internally, but also could result in ring seal etc down the road which would lead to oil usage eventually....
Steve@B&B
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 11:44am
I would get a sample  from both engines and have that tested before doing anything.  If you change the oil they can say anything to get out of trouble.  Remember how long it took to get Shell to admit wrong doing back when that happened to their oil?  Or was that Penzoil?
Edited by john(MI) - 22 Sep 2017 at 11:45am
ocharry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 7:37pm
So Darrel...I'm just curious .... How long after the oil change did the motors start this oil drinking???
Was it a few hours or a couple days????
Did they start smoking...liked they were burning it???
Or are they bleeding somewhere??? Like rear main seal or front seal..valve cover???
Think maybe the valve guides and seal????
That sure is a lot of oil getting away from them.....and both after an oil change....hmmm....I just am curious
Ocharry
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 8:50pm
They started using oil immediately. The D19 is being used to run a generator at a well to pump water for some cows. When we shut it off one day, we dropped the oil and changed it and the filter while it was still hot. Checked oil next day before we started it, and it was spot on full. Ran it for about 2 and a half hours, then shut it off. Next time we needed water pumped, we checked the oil before starting it, and it was almost down to add. Probably used it about four or five times since, and each time it was down almost a quart. With the one ninety gasser, we've raked with it three or four times since the oil change, and it has used about a quart every 3 hours. Neither tractor leaks more than a few drips. They aren't smoking. Both still run like Champs. I dunno. Darrel
This page was generated in 0.215 seconds.
