D19 HYDRAULICS
190XTLP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190XTLP Quote  Post ReplyReply Direct Link To This Post Topic: D19 HYDRAULICS
    Posted: 23 Jun 2010 at 11:13am
my D19 power director light comes on with hot oil at a medium idle and
when lifting a heavy load it lifts slow.Any ideas where to start?
WD45G,WD45D.190XTD,190XTLP
D19LP,WC unstyled,WF unstyled
WC styled,220
Bob(FL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob(FL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 12:03pm
I would start with changing the filter,  if that does not fix it check pressure, light on means low pressure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190XTLP Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 1:51pm
filter and oil is new,if pressure is low do you think pump
needs a rebuild?
WC styled,220
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob(FL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 1:59pm
you power director pump and hydraulic pump are different, sounds like you have more  than one problem.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 2:25pm
Is your main clutch slipping??
1968 D15D,1962 D19D
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 4:10pm
the pressure sender for the lite is up on the filter housing.  plug a guage in there and see what the pressure is and see if in fact it does go down.   All the PD pump does is pump oil to the filter and for lube of the PD gears.     Lifting is a separate issue, may be the pump has some check ball springs broken which will cut down the flow, the more you try to lift the slower it will get.  A relief usually doesnt act that way, it all or near nothing.  you have to pull the pump to get to the check ball springs.  HTH
