6080 injector pump |
mapleview
Joined: 18 Sep 2017 Location: Upastate NY Points: 5 |
Topic: 6080 injector pumpPosted: 18 Sep 2017 at 9:11pm |
I have a 6080 that will not rev over 1100 rpms and will stall at idle. I am suspecting the injector pump. Any help would be appreciated. Thanks.
DrAllis
Posted: 19 Sep 2017 at 7:20am |
You start by disconnecting the fuel supply line from the tank at the fuel filter base and see if there is a gushing stream of fuel coming to the filter. If not, you probably have a plugged fuel tank outlet.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Posted: 19 Sep 2017 at 7:51am |
If fuel supply proves good, loosen the pump timing cover on side of pump, and see if it runs properly while letting the fuel leak out that side cover.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 19 Sep 2017 at 1:04pm |
....and if it does...send it to Ed cause the flex ring is leaving....
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3659 |
Posted: 19 Sep 2017 at 9:25pm |
there is a plastic bleed screw on the back of the pump = loosen it while the unit is running - it should still run fuel out while the tractor is running - if it dies - see Dr,s post...
