Power unit 226
graveyard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote graveyard Quote  Post ReplyReply Direct Link To This Post Topic: Power unit 226
    Posted: 18 Sep 2017 at 11:20am
When running some numbers on my wd 45 I was told I have a power unit 226. any info on these motors and what difference are they than the regular 226 that came on a 45. Need info Dr Allis!!! thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 3:56pm
Depends if it is a G-226 (from a D-17) or a W-226 (from a WD45).  WHAT IS THE ENGINE SERIAL NUMBER BEHIND THE CARB AIR HOSE???
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 1:25pm
If the is no serial number stamped on the block behind the carb air hose, it has had a replacement block put in it at some time in the past. Replacement blocks thru the parts department were never stamped with a S/N.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2017 at 3:52am
Dr.
Will a G226 (D-17) block bolt up to a WD Torque Tube ?
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2017 at 7:25pm
Bolts right up to a WD/WD45 bellhousing.
