D17 Loses Power
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Topic: D17 Loses Power
    Posted: 17 Sep 2017 at 10:25pm
My D17 runs great as long as it has absolutely no load on it.  With the slightest load it starts to throttle up and down.  If I choke it half way it will throttle up an smooth out for a brief period.  Gas supply is good, I just replaced the fuel line and sediment bowl.  I also looked in the tank and there is no debris clogging the port.  I have also just replaced the points, condensor, rotor, cap and plugs.  I'm not sure if this is a new problem since this is the first I have used the tractor since I got it.  After I replaced everything I drove it around the yard and up and down the road and it purred!  Sorry for the long post and TIA for any help!
Edited by john(MI) - 18 Sep 2017 at 9:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 7:02am
Needs carburetor cleaned.     MACK
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 7:09am
sounds like dirt in air bleed to main nozzle , use fine wire (tag wire , bread tie ) to go in hole to make sure open
