AC 720 / Simplicity 9020 Gear Lube
rustydollar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustydollar Quote  Post ReplyReply Direct Link To This Post Topic: AC 720 / Simplicity 9020 Gear Lube
    Posted: 17 Sep 2017 at 5:02pm
Decided to drain the gear lube from the rear axle housings, the milky lube is from the left side and what little there is of the clear lube is just that not much in the pail.
Glad that I caught a potential problem.
I'll be checking the lube for iron filings and that's why I used two separate pails.
Edited by rustydollar - 17 Sep 2017 at 5:03pm
ShaunE View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote ShaunE Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 6:33pm
PM'd you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustydollar Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 6:46pm
Pressurized dispenser for gear lube, the tank was part A of a two part foaming agent. There's a tube that goes to the bottom of the tank that allows liquids inside the tank to be dispensed in an upright position.
Still have to add the schrader valve, the gun was originally designed to mix component A and B together before being applied. I have removed the mixer along with one supply hose.
These tanks come equipped with a safety blow off disc, after venting the tank outdoors I silver soldered the fitting for the pipe plug over the disc, then drilled through the disc afterwards.
This page was generated in 0.077 seconds.
