WD Belt Pulley
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: WD Belt Pulley
    Posted: 17 Sep 2017 at 2:33pm
I just looked at a WD that was for sale near me and the belt pulley had a lever to engage it that was separate from the PTO. I thought you had to engage the PTO to start the belt pulley. The lever was attached to the steering column support and had three notches in it about a 1/2" apart. I have never seen this setup before and was hoping someone could enlighten me about it. Thanks, Tim
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 2:40pm
It is an after-market shift mechanism. You would normally loosen a set screw and lock-nut then shift the pulley in or out as needed. This mechanism alllows you to do it from the seat!
Kindova neat feature, and I wish I had one!
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 2:46pm
What does anyone use the belt pulley for anymore?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 3:03pm
If you're a hobby farmer with maybe a half dozen head of beef it's nice to have an old hammermill. Those were belt driven. I never engaged the pulley until it was set, so it was no big deal to get off the tractor. It was kind of a kludge to go from one side of the tractor to the other to lock and unlock the clutch holder, though.
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 8:18pm
Do you go to tractor shows?  The weekend of September 16 & 17 we had a belt driven stationary corn sheller plus a threshing machine in use.  We also have a Baker fan that runs off a tractor's belt pulley.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 9:21pm
I went to the GOTO in Ottawa, KS Sept. 15, but had to leave before I could see everything. Lots of cool tractors and friendly people.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 11:19pm
Hi Rusty.
Look at LittleMarv's post about his recently acquired accessory. A front mounted buzz saw.
I have one and we used my 45 to run our hammermill when I was a kid at home on the farm.
Wish now that I had bought that at our farm sale or spoke for it before the sale.
BTW, I was born and raised and graduated(1975) down at Carthage.
You and/or your family may have heard of my dad, Alan, as he was a Funk's G seed dealer and distributor back in the day.
Edited by Jim Hancock - 18 Sep 2017 at 11:21pm
How blessed we are by HIS GRACE!
alleyyooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alleyyooper Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2017 at 7:22am
I also have a front mount buzz saw for my D17 that folds up againest the raditor for transport.
Is also the cats meow to start other tractors with a belt pully all by your self your working on.
I block the rear wheels and lock the brakes on the tractor to be started. Run the D 17 in line place the belt on the pulleys in a figure 8, Back thre D 17 up till the belt is tight and lock the brakes.
Get the belt a going to make sure I have it lined up properly, go back to the tractor I am wanting started remove thr clutch pedal lock I made and slowly let the clutch out and the engine starts to turn and many time will fire right up.
As fast as towing but doing it alone.
Big smile  Al
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2017 at 10:55am
Here's a belt pulley in use.  Spent all last Sunday running the threshing machine with the '28 Allis.
This page was generated in 0.324 seconds.
