D17 Series III transmission cover plate leak |
Smiling John
Topic: D17 Series III transmission cover plate leakPosted: 17 Sep 2017 at 1:03pm |
I have an oil leak on the right side of the transmission. It is the seal on a plate on the right side of the transmission behind the brake pedals that the oil lines to and from the hydraulic fluid filter go through. i do not know what is behind it, so will I have any difficulty reinstalling the plate if I remove it to replace the seal? Thanks.
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2592 |
Thanks(1)
Posted: 17 Sep 2017 at 5:24pm |
just two steel lines with o-rings that go into that plate from the transmission side
you can clean the two mating surfaces and make a gasket or use a thin bead of silicone.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Smiling John
Posted: 18 Sep 2017 at 10:37am |
Thank you ver much Acdiesel
DrAllis
Posted: 18 Sep 2017 at 10:59am |
It will probably take 3/4" line wrenches to loosen those nuts. There's not much swinging room for a wrench and platform removal helps if needed. DO NOT cross thread the lines when reassembling.
