D 14 Oil Gauge Not Working |
Post Reply ![]() |
Rod5300 ![]() Silver Level ![]() ![]() Joined: 15 Aug 2017 Location: Kentucky Points: 75 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Sep 2017 at 6:33pm |
Hello
I first want to report after advice from some of you fine folks I got my little 14 running pretty good. Problem was a couple things , took carb off adjusted everything again and mad sure it was clean and second, did the same to the tank, but after cleaning the tractor seems to run fine. so again thanks Now to this problem I installed a new oil gauge from a parts store , got it on and no oil will come thur the clear tube its not kinked and I can see it trying to come thur at back of the oil filter housing.. I know the oil pump is working as there is no pecking etc and the old gauge was so rusted I couldnt see the numbers,,, So again folks I need some advice from the smart allis folks. I thank you for your help. Rodd |
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
You can't use an auto parts store gauge on a D14. The filter is a bypass type and not a full flow, so the gauge does not measure the actual engine oil pressure.
You need the type of gauge that was originally used. It does not have numbers.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54129 |
You need a gauge that registers pressures from about 5-30 PSI. Most automotive ones won't go that low...
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
A 0-10 gauge will make you feel better. MACK
Thank You All for your insight. I didnt think about the oil filter not being full flow. Where can I get the correct oil pressure gauge Again thanks
JoeO(CMO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Do you have a "standpipe" in the center of your oil filter base?
Yes I think that my tractor has the pipe that the filter slides over. Thank You
Bob D. (La) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Louisiana Points: 25529 |
Go to any of the vendors on this site. They can fix you up.
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
What happened to the link that was at the top of the page that sent you to a list of the vendors??
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24695 |
My #1 D-14 runs at a steady 15PSI. I used a small 30PSI gauge screwed into the block/oil pump location where the oil gauge tube starts from. One day I should hookup a new line to the new gauge on the dash,figured I'd do that after it got painted....a lots happend in 15 years..cept #1 getting restored...sigh....
Jay |
LeonR2013 ![]() Orange Level ![]() ![]() Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Ain't it a fact Jay!
Jay ,
I sent you a PM Thanks to all of you |
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
You can remove the filter and see if oil is coming out of the stand pipe to be sure the pump is working. The pump may need primed. the oil pressure is built from the ball in the front of the camshaft and the resistance of the oil going thru the oil filter. The pressure on the gage is the exact pressure on the bearings in this engine.
If no oil is coming out of the stand pipe you can prime it by putting oil down the stand pipe. Using a hose on the stand pipe with the end in a can will cut down on the mess. |
The pressure will not be what is at the bearings. The pressure is from what is bled off to the filter.
Both will be the same. The gage measures in between the filter and the front of the camshaft. If a bearing gets loose the pressure drops every where and will be what is on the pressure guage. The filter acts as a relief valve the same as the ball at the front of the camshaft. The actual system pressure will caused be which ever one has the less resistance. If you hook a hose to a house water faucet with 30 pounds pressure and place a gauge on the other end with a ball valve after the pressure gauge and shut it down until the gauge reads 20 pounds the hose will have the full 20 pounds of pressure from one end to the other even though the water is still flowing through the hose. |
That's alright you will figure it out later! |
Let me know when you get your engineering degree
Norm Meinert ![]() Silver Level ![]() Joined: 31 Oct 2010 Location: Davis illinois Points: 470 |
I sell new gauges made in the USA. can call 815-238-4506
JimD ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mounds, OK Points: 2116 |
umm Joe, you might do a bit of research there.
We have new and used parts. 877-378-6543 |
I don't have a engineering degree either, but I know with a gauge teed in a line, the pressure will be the same at both ends as middle. MACK
corbinstein ![]() Orange Level ![]() Joined: 31 Jul 2014 Location: Oklahoma Points: 796 |
pull the filter and see if the stand-pipe is still there. I bought a D14 that had the stand-pipe missing because they thought there was something wrong with it for no oil pressure. I just connected the oil pressure guage to the pump fitting and did away with the filter entirely. turned out to be a good tractor.
Post Reply ![]() |
