? 4 Row Snap Coupler Planter
DakotaSteve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Topic: ? 4 Row Snap Coupler Planter
    Posted: 16 Sep 2017 at 3:44pm
So I was looking at the different versions of the 4 row snap coupler planter. It seems like one model has markers going straight up and one model has markers going forward, can anyone tell me why the markers would go forward? What was the purpose of this? If anyone has a picture of how they worked going forward that would be great I was told there was some sort of rope mechanism that you needed to run through eyelets on the front of the tractor
Also it looks like they are simply two two row Planters mounted together other than I have seen double-disc openers on the front toolbar in front of each row...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 9:12pm
Only one marker was forward while planting . They would automatically switch when you lifted and turned around at the end of the field . The one in the ground would stay put as you were turning and the other would extend out as the one in the ground got closer to the front of the tractor ,it lifted out as the other one extended . Tie the rope short to transport .at least that's the way I remember . My father planted every year with one . Yes 2 , 2 row planters on a tool bar , would think there was a 6 row also . I think they were called drill planters . Slow as you go as seed only drops so fast.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 9:18pm
Thanks, we're they only run on WD..WD45s? Could a guy put one on a snap coupler CA?
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 7:20am
Only if you weighted it a bunch. CA would handle it otherwise and be real handy to plant with.
This page was generated in 0.625 seconds.
