Tough 7G morning
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Tough 7G morning
    Posted: 15 Sep 2017 at 9:40am
Well while I await a radiator for our junk rustball dump truck I decided to tackle the 'weak' upper roller on my old machine. Was a little worse than "Weak"!!
Much gratitude to AC Mel for that good luck hat he sent me, got me thru this without breaking rail!! So glad I had my spare parts donor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 1:36pm
next up, got about 40-50 yards moved, new bucket working well as to cutting. Started getting hot out, around 100 heat index at noon, high humidity so decided was time to take a break and start working on those items needing NEW attention!!
Right sprocket nut backed off again, was backed off when I bought the machine, managed to get tight and set with the large punch/hammer method where previous leakage slowed WAY back, did again this time as does not come fully off threads, keeper plate bolts are all sheared, may need to weld it in place to complete this job.
Also have a trans leak under the floor plates, have to dig into that once cools some.
Edited by DMiller - 21 Sep 2017 at 1:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 3:30pm
Hmm as that nut is suppose to be at say 1000 ft pounds or so I figure a 10 ft pipe and my weight on it at about 8 ft out from wrench is about right torque on a HD5 sprocket nut - can't see how a hammer and punch could even come any where near right torque.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 3:54pm
Was loose way too long before I got the machine. The sprocket never fully tightens to the shaft from wobble but does get to where will not leak to this extent. I have driven the nut full around until stopped, will not take any additional movement and the sprocket still wriggles some. I have a donor machine as well a replacement shaft with sprocket on it sitting in my shop that came with the machine. Have a new seal(last one known to exist US) and new bearings, just have to get time to get the truck off.
Taking the rear of the truck off with a gas axe or saw I do not think will fly, the 7G has a added side reinforcement and the sprocket does not clear the last roller flanges, rides inside the cup region.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 3:56pm
It does have that odd flared bolt to the loader frame as the 6G did.
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 8:09am
That looks like a 73 chevy c60 or c65 dump .we have had a few about 5-6 two had one number difference in the vin number . most of them had 366 or 427 engines in them with air brakes and tag axles. The last one I had was about 10 years ago had about 14 tons of gravel dumping and the left frame rail broke . so with a broke frame and everything else worn smooth out I took the 12 yard bed off and sent it to china .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 12:17pm
This one is a bit newer but maybe more rusted! Is a 1985 C70, 366 4bbl with a mostly wasted crash box Clark trans, hydraulic disc brakes, electric clutch engine driven PTO which is weak as snot. Left door window frame rusted away and the window sits off angle won't go up or down, the entire wagon should have been one to go to China!! Yet it does move dirt, around four to five yards a shot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 2:01pm
All of our truck had the manual pto . 18-5 2 speed  rear ends with 5 speed tranny. the one before last the electric 2 speed kelp burning up so we put a air 2 speed in it and never had anymore trouble out of it . the 427 model would haul 12-14 yards of dirt up the river bridge with a blink of an eye .the 366 would start talking about half way up. they were some good old trucks in there time .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 5:39pm
Well got the nut set, pressure washed, hose replaced and washed then welded nut retainer. Topped off fluids and down the hill, only to see the stack begin to twirl. Thought at first stack pipe broke, NO, the elbow after the turbo broke between the square and round section the pipe is attached to. Back to the shop we came.
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 10:21pm
Dave....Oh Dave....are you wearing the magic hat?...You didn't leave it on the track when you took that picture did you? You're having to many issues to have that hat on. Maybe you need a blue one to go with the orange one....They have other medicinal qualities that could help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2017 at 6:27am
Morning Mel,
No the hat(s) have been fine, been good for luck and keeping sunburn off an old brain!!
This was bound to happen, been abused before I got this far and still throwing up a bit now and then. I believe I can weld this back, the old T04 still has the four bolt holes flange available so may end up building something off a heavy 90 exhaust pipe from there. Still seems as I push it harder it does get a bit more temperamental!! Wouldn't happen to have a old 7000 scrapper sitting with one of these on it?
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2017 at 5:24pm
Thanks for sharing DMiller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2017 at 6:23pm
Some days you eat the bear, the bear ate me up last two days!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2017 at 7:09pm
It goes that way. Eating meat one day and feathers the next.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2017 at 11:13am
Aint pretty but have built up the steel where there was none. Will allow the days heat to pass and overlay the entire weld tomorrow to clean it up some. Will need a total replacement later as this one is pretty well used up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 9:54am
Good job. Looks pretty solid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 10:37am
Made a 7018 3/32 overlay on it this morning, then back to work. All is hanging in there including the heat for now so gave up for the day.
Sprocket is hanging in there minimal leakage once again.
Post Options Post Options   Thanks (1) Thanks(1)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 11:18am
This heat is no joke .Saturday I was pushing up scrub brush and was ringing wet with sweat by 10am .went back around 4pm and worked till dark and was soaking wet with sweat again .
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 11:58am
I believe it. I was in Florida all last week with family, temps were high 90's each day and humidity was almost 100% every day. You couldn't breathe.
Came back home Saturday to Michigan, same weather and they had it all week. Our Michigan schools do not have air conditioning and they are still only having half days due to the heat.
Crazy. Starting this Thursday we are in the mid 60's during the day and 40's at night.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2017 at 8:47pm
whoo hoo. Cat fishing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2017 at 9:14pm
Late season pike!
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2017 at 9:01am
Sorry Dmiller, no tag at all
Edited by CAL(KS) - 29 Sep 2017 at 9:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2017 at 6:32pm
Thanks anyway. Looks to be a different make anyway.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2017 at 10:45am
Yesterday I found a HD7G elbow and no parts number on and dimention are 3 7/8 inchs on top, the flange 5 inchs,patern bolts 2 3/4 inchs and he is 9 inches hight
