6080 steering issue
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: 6080 steering issue
    Posted: 11 Sep 2017 at 11:36pm
I think another forum member had asked this not to long ago but I don't remember the responses.
Say your going straight and tractor is drifting to the left you have to turn the wheel quit a bit to right to get it to do anything but the other direction is fine. What you think is going on. Could a leak do this. I say that becouse I notice the dust is wet around like the lower dash bolts and where the clutch pedal goes through lower dash but its not enough to make a drip. IV opened lower dash and can't see a leak. But I'm going to try to clean off all the fittings on steering colum see if its any of them.
Thanks
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 7:38am
Steering control valve needs rebuilt. Ackward to work on but not the end of the world. Label your lines well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 8:04am
2WD or FWA  ?????????????     I'd rebuild the steering cylinder first. Rebuild the orbitrol??what are you going to do to it other that reseal it ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 8:20am
It's 2wd
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 10:11am
Mine has the same symptoms and a o-ring kit from Agco took care of it. How is rebuilding the steering cylinder going to fix it being damp below the dash?
Edited by victoryallis - 12 Sep 2017 at 10:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 10:19am
It's not. The wandering steering probably has nothing to do with the orbitrol. If there's a leak at the orbitrol, a seal kit will take care of that, but not the wandering complaint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 11:09pm
Dr even if the steering ram is dry. I had it done maybe four years ago when seal went and was blowing oil out.
When you say orbital you mean what steering wheel goes into. Whats the kit number victory allis.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 6:57am
I would have to call my dealer to get the number it's been 10 plus years since I did mine. Yes it's up under the dash sorta ackward to access.
If you can't find a seal kit let me know I will find out a number for you.
You also will need some tiny 12 point sockets to disassemble it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 7:20am
Steering cylinders can (and do) leak internally, causing a steering control issue. Just because it's dry on the outside doesn't mean it isn't leaking inside.
orangeonly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeonly Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 10:04am
I'd listen to dr. on this one. We had same issue a couple years ago. Same thing no leaking out of steering cylinder. He said its cylinder 99.9 % of time. Rebuilt cylinder been working fine ever since.
If it ain't orange it ain't worth ownin'
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 7:19pm
Ok thank you
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 10:00pm
+2 rebuild cylinder...
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2017 at 6:45am
Your steering control valve leaks either way it needs resealed do that if it still drifts redo the cylinder.   Do one repair then if necessary do the second.
mtanut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mtanut Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2017 at 9:51am
just had my steering cylinder rebuilt on my 6060 problem solved, no more cranking to the right all the time
I have a 185 Allis, 6060 Allis, Model K gleaner, SMTA ferg 35, ferg 20 (paps first tractor, Allis B (wife's)John Deere 240 skid loader and a bunch of the usual farm stuff.
ssefick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2022 at 8:49am
Any idea on the agco part number for the orbital seal kit?
My 6080 is leaking and I need the orings, I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2022 at 7:55pm
Oh I see I never gave an update. It was like dr said. Had the steering ram rebuilt and problem solved.
Thanks dr 4years latter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2022 at 8:02pm
oh and seal kit part# is 70265995
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2022 at 8:27pm
Thank you. Ordered today!
