Allis Chalmers D14
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers D14
    Posted: 11 Sep 2017 at 9:03pm
I recently bought another tractor. It's a 1957 D14. It is supposed to run but had the carburetor remove to replace it with a rebuilt correct one. It also has a cracked block.
Whoever painted it did so over a lot of dirt and grease. The hood panels are pretty rough with the exhaust hole torched out on the left one. It has a 3 point adapter.
The best part it has nearly new tires. 14.9-26 rear and 6.50-16 front.
I thought it was worth the $1250 I paid due to the new tires and rebuilt carburetor from Stiener's. I hope the engine is good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 6:10am
Joe you did REAL GOOD !! I'd even paid a little more for it but ,shh, don't tell the wife !!
I'd remove gas tank and line, and clean them out REAL good, add fresh gas, confirm it flows out well, into a 5 gal bucket, for 3-5 minutes. Then connect to carb and fire her up.
Jealous Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 6:55am
The tires and 3 point adapter are worth more than you paid for the whole unit. You did good!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 7:25am
The gas tank was already removed and cleaned. Just missing the sediment bowl.
I did not haggle on this one. I paid the asking price.
It would have been better if it had power steering like the other D14 I bought. My brother has a front support with power steering. just need the pump and lines to complete the change.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 5:16am
looks a lot nicer than the 1960 d14 i paid $1000 fer. mine does have psteering and a loader, but looks old!!
This page was generated in 0.095 seconds.
