Removing shift lever on a WC
Ron-SE IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron-SE IA Quote  Post ReplyReply Direct Link To This Post Topic: Removing shift lever on a WC
    Posted: 09 Sep 2017 at 7:08pm
How do you remove the shift lever on a WC transmission?
Thanks
Ron- SE IA
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2017 at 7:57pm
Ron, you have to remove the shift top and turn it over so you can remove the reverse lock out mechanism, then you can remove the lock ring and pull the shifter lever.
I have a PDF of the WC shop manual, I just sent a down load link for it to your email
Joe
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2017 at 8:15pm
I just did one, maybe this will help?
Be very careful when removing the rails- the detent balls come out with considerable force!
And to remove the reverse lockout, you have to unhook the rod and let it travel farther than the lever actually allows. Clear as mud, but you will see what I mean.
Edited by littlemarv - 09 Sep 2017 at 8:19pm
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron-SE IA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2017 at 12:49pm
Thanks for the information.
Do you have to remove the middle rail to get to the reverse shift latch?
Thanks,
Ron-SE IA
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2017 at 8:21pm
I do not know. I've only done one, and I had all three out already.
