WD In Progress
bradytlb1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradytlb1 Quote  Post ReplyReply Direct Link To This Post Topic: WD In Progress
    Posted: 22 Jun 2010 at 5:56pm
Don, on the auxilary ram connection is that only used for lift and lower like the hitch rams or can it be used for rotary tools and if so where would you hook up the return line?
Thanks.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 6:22pm
You can only run (or use) the auxiliary ram on a WD/WD45, They are a one way pressure flow system. It will not run orbit motors. Sorry.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradytlb1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 6:34pm
Thanks Don.
This page was generated in 0.234 seconds.
