Opinions about an HD11 on CL |
Ferdinand
Joined: 31 Mar 2016 Location: North Carolina Points: 1951 |
Topic: Opinions about an HD11 on CLPosted: 09 Sep 2017 at 8:37am |
What do you guys think about this dozer? Is replacing the driveshaft a deal killer?
https://raleigh.craigslist.org/hvo/d/allison-chalmers-hd11-dozer/6257270810.html |
Because narrow is the gate, and narrow is the way, which leads unto life, and few there be that find it.
Mathew 7:14 |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35666 |
Posted: 09 Sep 2017 at 3:12pm |
First it would have to run, there are parts machines out there for a shaft MinnPar may have components as I do not know why it would need an entire shaft. Has Rockwell bolt down u-joints so may be able to purchase thru a truck shop by dimensions.
As to the $4000, rails are shot, shoes are too where those are a non-available. Have toyed with installing Cat 6.906 rails on worn sprocket but if have bad rollers then the trucks will need come off for mod to another manufacturer. Again it will need to start and run for $4000. |
Lazyts
Posted: 09 Sep 2017 at 9:39pm |
Lots of good parts- should be work $4k- I just paid that for this one with a blown engine and bad undercarriage- still too good to scrap.
AC Mel
Posted: 09 Sep 2017 at 11:06pm |
Ok...I'll weigh in on this...normally a drive shaft would be a simple fix....butttt.... more than once we've seen these driveshafts destroy the torque converter shaft leading to torque converter removal and replacement of shaft....which are hard to find. It would be good if you could look at the tractor and check out the drive shaft. Then again maybe it's as simple as changing a u joint. If you only have one of these tractors and need all of those parts and some undercarriage too...it could be very expensive.
Soooo...all that being said...I'm going to sign on with Trevor...if you had more than one of these tractors (he does...we have 4) I would pay $4000.00 in a heartbeat for this for a parts tractor...hope that doesn't confuse you to much. |
Ferdinand
Posted: 10 Sep 2017 at 11:19am |
Thank you, gentlemen. If I were to buy it, it would be my first dozer purchase. Nothing around here but, a couple of small farm tractors.
Maybe tackling a monster like this HD11 is a bit too much for me. |
Mathew 7:14 |
DMiller
Posted: 10 Sep 2017 at 3:45pm |
If you could find another in the same price range that was running and working then buy this for parts.
Edited by DMiller - 10 Sep 2017 at 3:45pm |
Josh H
Joined: 24 Feb 2015 Location: Carnesville, GA Points: 128 |
Posted: 10 Sep 2017 at 7:26pm |
Hey, is that a 16b to the left of 11b? Should of uploaded that one!
One problem is getting it on and off a trailer |
HD6 Merv
Joined: 03 Aug 2010 Location: New Zealand Points: 501 |
Posted: 11 Sep 2017 at 4:14am |
looks like you got a good buy Trev
even came with a 'wench' for you ! Cheers Merv
tits tyres and tracks
they all cost you money |
