AA 6690 PTO PROBLEMS
Craig/insoh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig/insoh Quote  Post ReplyReply Direct Link To This Post Topic: AA 6690 PTO PROBLEMS
    Posted: 22 Jun 2010 at 4:55pm
I am haveing trouble with mechanical controlled pto on an agco allis 6690 does anyone on here know what the problem could be that the pto shaft does not turn?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig/insoh Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 10:16am
Pat SW Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat SW Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 9:25pm
Make sure the lever above and to left of the PTO shaft is pushed forward for 540 or pulled back for 1000 rpm.  Also a light on the dash will show if it is either in 540 or 1000 and I think there is also a neutral position
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig/insoh Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2010 at 9:43pm
That part works 540 economy and 1000 light also works! It's the mechanical control lever on the other side that turns it on or off that doesn't seem to be working! I've been and haven't got the pan under the seat off yet to see what make things tick. Parts book doesn't make it clear on wheather the switch under there on manual control lever linkage works a solenoid or just a safety light! If you pull the PTO lever the light comes on on the dash but PTO doesn't turn!
This page was generated in 0.046 seconds.
