Water to Air intercooler video
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Topic: Water to Air intercooler video
    Posted: 05 Sep 2017 at 9:09pm
Interesting to see the difference in air temp as air enters and exits  intercooler. There using car exhaust, so how real life are these temp numbers on a turbo diesel ? I realize a lot of parameters play a part in the result.
Edited by Beirnesy - 05 Sep 2017 at 9:22pm
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
BKarpel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BKarpel Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2017 at 12:30pm
When using a air to water intercooler with a ice box. You can get your air down to around 40 degrees and keep it there for the hole pass.
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2017 at 8:58pm
A good air to water intercooler is the cheapest power you can add to a turbocharged diesel puller. The power will go up and the ft. lbs. of torque will increase dramatically. Anyone who pulls (and the rules allow) should have one.  It will also allow you to turn a larger turbo as it "fools" the turbo into thinking the engine is bigger than it really is.
Acllss puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2017 at 10:26pm
Yep if you can run one use it ! Hey mike looking for a 3rd gear around 29:1 in a 190 rear . Got Anything or what a tooth count to get that ???? Thanks Mark
