615 gas motor question
Orange4ever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Topic: 615 gas motor question
    Posted: 02 Sep 2017 at 8:10pm
Found a allis 615 with a gas motor, has mounting brackets for a backhoe, arms for three point hitch, and a 21 spline PTO shaft. Currently has a weight box on the back. Is this a 1000 rpm for running a backhoe attachment or a 540 that somebody has changed out? I've never seen a 21 spline on a gas tractor this small.
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2017 at 6:51am
I have the same set up with an I 600. The backhoe mounting brackets are a standard part of the loader frame. To mount a factory backhoe, the casting that holds the PTO and the 3 pt hitch has to be removed and the a cover plate installed. It will become a 'bareback' tractor. The PTO has 21 splines but is actually 780 rpm on tractors equipped with a 'shuttle'. This is because the base tractor was designed as a D-15 farm tractor and with the two speed Hi/Lo 'power director' the PTO is standard 540. Shuttle is achieved by reversing the low speed clutch pack with the weird PTO speed a result.
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2017 at 7:06am
My PTO shaft is 21 spline on my Allis HD4 dozer. I wonder if anyone has ever found a adapter that is 21 spline on the female end and the modern type 6 spline male found today ? I would like to mount a post hole drill on the back of the dozer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2017 at 8:14am
Common adaptor that most farm dealerships will have.
This page was generated in 0.103 seconds.
