D17 Series IV Starting Problem
Too Tall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Too Tall Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series IV Starting Problem
    Posted: 01 Sep 2017 at 5:22pm
It will sometimes turn over once and I will let up and try again a few times and it will start.  Battery must be at full charge to whirl it.  The cable from the solenoid to the starter will get real hot almost immediately.  With a new battery it still drags before it takes off.  So far I have replaced the solenoid, the cables from solenoid to battery and to the starter, and a new battery key switch and starter button.  I am leaning toward it being a tired starter but would appreciate other ideas before I shell out that kind of cash.  thanks
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2017 at 5:43pm
Could be starter problems like worn bearings that are letting the armature drag on the field pole pieces, worn brushes that don't have good contact with the commutator, bad windings, or corroded commutator.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2017 at 5:50pm
First thing to do is a voltage draw test, on the starter, on the tractor...Wink
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2017 at 6:51pm
If the cable never use to get hot I'd lay odds on it being the starter. It shouldn't cost a fortune to have the starter rebuilt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Too Tall Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2017 at 11:41pm
I will check the voltage.  Does anyone know of someone on this forum, or elsewhere, who rebuilds starters and may have one for an exchange.  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2017 at 3:53am
Check your Yellow Pages for "starters, rebuilding." I believe SteveNJ does it too.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2017 at 6:09pm
SteveNJ does indeed rebuild starters. Good guy. Get hold of him and see what he says.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Too Tall Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2017 at 3:48pm
Finally  put on a new starter and it starts fine now.  Is the old one worth anything to anybody to rebuild?  Shipping would be a little costly I reckon.
