b model thermostat
gman11110 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gman11110 Quote  Post ReplyReply Direct Link To This Post Topic: b model thermostat
    Posted: 01 Sep 2017 at 6:50am
1952 b model   just wondering if I need a thermostat .  checking a few things on this new project I picked up  noticed there was none.  how important is it to install one or leave as is.....
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2017 at 6:08am
They used shutters to control he heat. There should be a hole on the right side top for the adjuster. Shutters can be found.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2017 at 5:05pm
By 1952 they had thermostats installed... Most of them leak by today, or were removed and run with none... Thermostat is always a good idea to maintain a constant 180 degrees, but like I said, MANY don't have one today... if your running in the summer in LA, probably not that big of a deal... If your going to use all winter, might be a good idea.
This page was generated in 0.146 seconds.
