Hd6 ?
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Topic: Hd6 ?
    Posted: 30 Aug 2017 at 9:37pm
Is it possible to convert screw track adjuster to hydraulic and how did you do it. Thanks.
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2017 at 7:00am
Yes My HD6G has one screw type adjuster and one hydraulic adjuster that I made.
I have a better design If I ever do it again. I would consider selling this one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2017 at 12:18pm
Were did you get hydraulic cylinder? What size you use? Details pls.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2017 at 4:54pm
I designed it in autocad. I can mail a copy of the drawing I worked from if you have access to a machine shop. PM your address. I used 2" ID 0.250 wall DOM tubing 15" long. The thread on the AC adjuster is 1.600 OD 5.5 threads per inch.
Like I said I made it. The rod diameter I used is 1.750 Dia. A purchased hydraulic cylinder would not be up to the task.
R.KYLE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.KYLE Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2017 at 8:13pm
DOZER GOOD INFO I HAVE TO KEEP THIS IN MIND . I MAY WANT TO TRY THAT THIS WINTER ON MY TRACTOR
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2017 at 6:14am
Very neat job. One good thing I noticed was it still has the place to use the wrench on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2017 at 7:59am
Also note that I drilled and tapped (2) places on the yoke for grease fittings. The original screw adjuster was rusted in place. I drilled these holes to lubricate the screw so I could remove it.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2017 at 12:35pm
Not saying what you may find, but always check out Surplus Center for hydraulic cylinders for odd ball uses. If you have room for bigger than you need,I would beat you can find one for a very reasonable price.
