L3 oil cooler housing gasket leak
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Topic: L3 oil cooler housing gasket leak
    Posted: 30 Aug 2017 at 7:53pm
Had the gasket start leaking where the oil filter housing mounts to the block on my late L3 with the 670 motor. I replaced with a new gasket, cleaned everything up and used black permetex/gasket sealant. Put it back together and it leaked in a different spot of the gasket. Ruined it taking it apart so I bought another new gasket and installed it dry. It still leaks. What am I missing? Should I use sealant or not? If so, what type? Thanks in advance.
