Hydraulic Fluid 6060
Eddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Fluid 6060
    Posted: 29 Aug 2017 at 4:12pm
Does the Hydraulics and transmission on a 6060 use the same fluid?
Allis Chalmers 6060
10' Howse Rotary Cutter
5' Tiller
5' Box Blade
4' Aerator
Ferris Zero Turn Mower W/10' fold up sprayer
John Deere 455 Lawn Tractor
John Deere 955 w/loader &
60" belly mower
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2017 at 6:34pm
Yes use the same 821 spec fluid.  Different fill points though, I think the trans takes 3 gallons.  Can't remember what the rear diff takes for a total.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2017 at 8:28pm
Thanks, I thought so. Had a hydraulic leak topped it off and before I use it again was going to check the transmission and wanted to make sure I could use the same thing!!
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
