716 speed change
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: 716 speed change
    Posted: 28 Aug 2017 at 7:54pm
I need to slow down the speed in second gear a little bit. Should I go with a pulley 1.5" smaller than the original and run 1st gear, or go with one 2" bigger and run in 2nd gear? Wondering if anyone has done it. Thanks!!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2017 at 6:10am
A smaller 'drive' pulley or a larger 'driven' pulley to slow down ground speed.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2017 at 7:07am
Yes, that's right Gary.  I was just wondering whether it would be more beneficial to speed up first gear, or try to slow down second gear.  There is a big jump between the two.  I may try to slow down second gear.
