190xt power director for pulling
Justthemechanic190 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justthemechanic190 Quote  Post ReplyReply Direct Link To This Post Topic: 190xt power director for pulling
    Posted: 27 Aug 2017 at 3:31pm
Looking to upgrade the power director in our 190. Really want to keep it vs. just deleting it. Can anyone out there point me in the direction of where to get one or what i need to build one.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2017 at 10:23pm
Unless you want to machine one out of steel, you have a piece of cast iron spinning at engine rpm made of 2 halves held together by 6 small bolts. Pullers in the past state if left to max 3000 rpm and - depend on who you talk to 400-600 hp it will hold. There is nothing heavier than the 9 plate clutch. 5 plate low 4 plate high. Pressure to the cluthes above 350 psi is iffy.. These units are getting old and metal fatigue is a factor. Slippage is one thing - an exploded clutch is dangerous.
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 7:03am
Who sells a coupler to delete it
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 7:44am
this is a 250hp farm stock, running 2800.
ACman75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 9:31am
Gary (wi) a coupler from 185-200 dual speed pto will fit right in there. Get from a salvage yard. Just removed my PD And used a one of those couplers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 9:34am
The power director I removed, had been reworked so there was no neutral between shifting with it. I would be willing to get rid of it. Not going to use it anymore. It has its ownhyd pump that is belt driven from crank. Pm if you interested
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 10:57am
I would be interested in the modification to have no neutral - unless one just had a valve that would make it that away instead of mods to the clutch..??
Any way back in the early 70's we ran at more Rpm than that Ed, in a 190 and later a 185 at about 250 300 hp with a stock PD unit - 30.5 tires 7th gear in 7000# on some tracks, 6th gear on most tracks in 7000 and 9000 # classes. There was a 190 - Taylor and Cheek out of N Ky that ran with twin turbos that ran the PD for a while. Later took it out and put in the 70230321 coupler with the center snap ring as we did. This 190 info came from JB who followed and helpd them ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 6:13pm
The one I have was setup with flow limiters so it shifted like a TA with no neutral pause
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 6:42pm
AC man 75 you got it going on then
Edited by DougG - 28 Aug 2017 at 6:42pm
NA G301 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NA G301 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 7:48pm
very interested in by passing newtrell  we are running 3 gpm gear pump and had to add a home made acumulater to line to get a smooth shift.This is in a 190xt gas NA @ 3000 rpm 5750 wt vintage class . Hydraulic presser is set stock.The only remaining stock hy is the sift vale
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2017 at 12:36pm
I will sell the one I have if anyone's interested
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2017 at 12:46pm
What valve gets replaced? The external one?
Charlie
