WD In Progress
bradytlb1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradytlb1 Quote  Post ReplyReply Direct Link To This Post Topic: WD In Progress
    Posted: 21 Jun 2010 at 7:38pm
Quick question, for the auxilary ram hose connection does that connect to the second port out of the hold valve body or is there another port that I have not located yet. The two ram cylinders are connected out of the port that would on the right hand side of the hold valve and the other one is plugged off that is on the left side.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 9:56pm
Yes that's the one you need to use. Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradytlb1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 2:38pm
Thanks Don.
