6080 PTO Problems HELP!
sherman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sherman Quote  Post ReplyReply Direct Link To This Post Topic: 6080 PTO Problems HELP!
    Posted: 26 Aug 2017 at 3:16pm
I have a 6080 FWA tractor and the pto drive wont move at all, with right lever down and seasonal disconnect up(left side). Never happened before..... can move left lever up and down while tractor is running.....feels like its still clicking in . Any ideas ?
still have 70 acres to cut and 130 to bale.
thanks.
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 10:07pm
If you can move that lever on the left by the seat when it is running, up and down, and you don't have any gear clash most likely something has happened on the engine pto clutch.  The seasonal disconnect is just a collar that slides on the pto shaft.  Could be the cable from the long lever on the right is not letting the clutch apply all the way?  Check to make sure it is loose when lever is moved ahead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 10:15pm
Sheared pin in lever on left side. Happens quite often.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote sherman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 10:51pm
Thank you for the help, yes Mack you were right, shear pin gone, now replaced and able to go bale first and cut some more.
