Won one; lost one
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: Won one; lost one
    Posted: 26 Aug 2017 at 8:47am
Had a little time to work on the forty five road grader yesterday, so we took advantage of it. We need it to get the hay area shaped up for hauling hay in. The worm gear shaft for the circle gearbox had bearings out, and the shaft was messed up at last report. Had a new shaft made, and got new bearings, races and seal lined up and ready to go. All went together with less trouble than I'm used to experiencing. Should have been a red flag! LOL! Then the next red flag, the thing turned over about 3 times and fired right up. Hasn't been started in at least six months. This is getting to good to be true. Then the tide turned. The knuckle buster lever for the circle only worked in the forward position, turning the circle clock-wise. Pulling the lever back to turn the circle counter- clockwise only resulted in a little mild chattering, but wouldn't turn the shaft. My plans are, when I get back to this project, are to pull that segment off the knuckle buster box off. What am I going to find there? Do I have to take the whole box apart, or is the problem going to be in the part that come off of the top? My back-up plan, if the gearbox fix is in-feasible, is to put an orbit motor onto the in-put shaft of the circle gear box, and run it off the auxiliary hydraulic pump with a two way valve in the cab. Any thougths...? Insight...? Anything for the good of the order....? Thanks, Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 9:16am
Have one of the boxes on my Adams grader do the same thing - keep saying I should fix it - then remember I seldom use the machine so why bother - just 2 hand that lever so it doesn't chatter my teeth along with the gears - push hard it will go easy
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 5:20pm
Darrel
Jensales copy of AC-S-45MG page 97 "3.  Power Control Box"
Says you can swap the dog clutch gears front to back and get new wear surfaces so if yours haven't already been swapped you can get another life.  I guess you turn the selector sleeve over too.
I haven't been in here but I guess you take the back off the housing and that control tower off and then things should come out.  And I could be wrong.
If you were to go hydraulic motor I'd be interested in what you use.  Ours has the wheel lean now done with a cylinder which walks a bit.  So I've thought of using a motor on the lean gearbox (which I'd have to scrounge as ours is gone).
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2017 at 5:48am
Darrel...just run it one way, take a breather or a swig all while it goes all the way around to where you want it again! lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2017 at 9:04am
Uhhhhhh, The front wheels get in the way........ Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2017 at 3:23pm
what...no blue tool?
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2017 at 3:31pm
Sometimes I have to wonder if your elevator goes all of the way to the top! LOL! Darrel
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2017 at 3:46pm
Darrel, we knows his elevator goes to the basement floor,   an then some more.Evil Smile ... Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2017 at 4:50pm
Have you got the bolt on moulboard extensions then?
They did have hydraulic side shift as an option.  It would be handy on ours but that hydraulic circuit has been farmrerised for blade roll.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 8:23am
fork and cogs may be worn inside the box.  on my 145 had the same trouble.  switched it out with the unused fork/lever and shimmed in the problem gear.  problem fixed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 12:21pm
Forgive my ignorance here Cal, but is that all do-able without taking apart the entire gearbox. I'm completely unfamiliar with what goes on inside that animal. Thanks, Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 1:34pm
ok Darrel you are in luck.  the 45 and my 145 share quite a few components.
  pull up this link.  pg.  248 of pdf or pg 246 of the parts book shot the control box breakdown.
 the upper right show the breakdown of the shift fork mechanism.  i had one with one side broken off.  the assembly pulls straight up after removing  4x 3/8 bolts.  you can inspect the fork and the engaging dogs item (17 and 18 gearbox pic) . they can get very rounded and not engage or chatter/jump.  my blade circle would work one directon but not the other.  after several attempts and not finding anything particularly bad/broken  i did noticed that my case head (#2)  was worn where that particular gear was.  i added a machine washer between the gear #17 and case head and that fixed the problem.  there was just enough wear between items 17,18 and 2 that it would not engage fully.
you could have a broken gear, cog or shaft, but you should be able to tell by pulling off the control lever and draining the oil.  which you will probably want to do anyway if its been setting outside.  i have been into that gearbox as well as the pto box with new bearings and rebuilding the pto driveline.
i have a bucket of extra gear case/misc parts. i might be able to help you should you need something.
Edited by CAL(KS) - 28 Aug 2017 at 1:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 4:42pm
Cal
As noted above you can reverse the 17-18-17 assembly and get new wear surfaces - if it hasn't already been done
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2017 at 8:46am
Originally posted by Ian Beale Ian Beale wrote:
Cal
yes,  as they turn opposite directions.  i didnt think  to mention that.  thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2017 at 11:14am
Thanks so much for the information, guys. I have a lot to go on now. I know that I am not going to have time to get back to this project again for a while now. But I'll let y'all know how it goes when I do get to it. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2017 at 2:24am
now what are you moving on to? prolly gonna clean on the Quonset?
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2017 at 2:36am
I've got 13 miles of interstate road ditch to hay. Have 100 acres of oats that we Hayed once already (only made half bale per acre) and it came back. Going to hay that again. Will have about 30 acres of silage corn to chop right at about first frost time. Then will have some buckwheat to swath and combine. And then some sunflowers to combine. After that, get ready for that pretty stuff that you love to send out all over the country. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2017 at 12:40pm
Shameless, I thinks for all the troubles ye sent ol Darrel last winters, ye should go ups and helps him get ready for your mischeiviousnous with that snow machine your goin to do this coming winter...
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2017 at 2:05pm
Yes, I agree with JC
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2017 at 3:09pm
Still coming down to seeing Ducks flying south already, trees turning color already and almost Every Day foggy in August which is the number of 'significant' snows by the old wives tale to come.
Ain't right, too early!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2017 at 10:11pm
if'n I takes "the machine" up to Darrel's place, all that wide open country where the wind really likes to blow, it should scatter all that pretty a LONG ways, prolly farther than just from my place!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2017 at 10:52pm
Shamelush, are ye talkin about before ye helps Ol' Darrel or afters ye helps him get everything done befores ye fires up that wicked machin ah yours...?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2017 at 2:34pm
NOW YOU KNOW OLE SHAMELESS AIN'T going to help poor Darrel, he just likes to torment him
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2017 at 6:23am
Originally posted by tadams(OH) tadams(OH) wrote:
NOW YOU KNOW OLE SHAMELESS AIN'T going to help poor Darrel, he just likes to torment him<div id="UMS_TOOLTIP" style=": ; cursor: pointer; : 2147483647; : transparent; top: -100000px; left: -100000px;">
whew, glad someone has caught on to Shameless. That guy kicks ya when you're down. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2017 at 2:55pm
Then he likes to pock ya with his sharp stick too
This page was generated in 0.122 seconds.
