7000 series jumping high range
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: 7000 series jumping high range
    Posted: 25 Aug 2017 at 10:56am
I have a newly acquired 7020 that jumps out of high range on the road. It feels like it engages good. It shifts easy in high low and park. Is there something I can adjust? It's a low hour tractor and I can't imagine it being ground enough to make it jump but??
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 11:38am
make sure the lever under the floor board is going all the in to the detent. you may have to adjust the cable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 12:05pm
The only 7000 series I ever had do that had been shifted on-the-roll from Low to High and had all the teeth ground off. It didn't have many hrs on it either.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 12:30pm
Dr,  what about one that jumps out of reverse?  7045 does that, under load or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 2:33pm
Power Director I assume??  Usually linkage is worn or loose enough it isn't fully into reverse. If it truly detents into reverse and jumps out, I'd guess it's been ground into reverse too many times..............
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 10:31pm
There a lot of them that jumps out of reverse under load. I have one.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 9:15am
Yes, power director.  Well, I don't know what owner of the tractor I am.  I'm not the one who ground it into reverse, but it may very well have been, who knows.
Mack, I don't know whether to take comfort or concern in you statement! lol
