2nd favorite tractor question about see. #
AC/LIFER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC/LIFER Quote  Post ReplyReply Direct Link To This Post Topic: 2nd favorite tractor question about see. #
    Posted: 24 Aug 2017 at 3:04pm
I have a JI Case older tractor. SC, VAC, ?. It's missing serial number tag on the dash. Is there a serial number maybe stamped into a casting somewhere? You guys are always willing to help. Thanks in advance!
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 3:14pm
I had a VAC several years ago.  The serial number was on a plate on the dash, out from the steering column.  The SC may be the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC/LIFER Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 3:31pm
Yup that's what's missing Larry. Appreciate the quick response. If anyone wants to take a gamble on a tricycle front end JI Case tractor it's for sale near Peoria, IL. I can text or email pics of it to you.
Thanks for all.
saele View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote saele Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 7:02am
It is also stamped into the bell housing of the engine on the left hand side behind the air cleaner.  Only time this number is incorrect is if the engine was changed.  My Serial # is off by about 1700 units as I had to replace it.  I was glad the 2 numbers were both mfg. the same year.
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 9:02am
Post a picture. I might be able to narrow down a year, based on if it has certain features.
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 1:24pm
dad had a VAC for years, was the packing tractor and spraying tractor, sometimes a jockey tractor. no 3rd gear and no brakes or hyd's they all broke!
