Charlyn PTO Pump Part Needed
Gary (e.c.mo) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (e.c.mo) Quote  Post ReplyReply Direct Link To This Post Topic: Charlyn PTO Pump Part Needed
    Posted: 21 Jun 2010 at 3:10pm
Guys I need the front half of the pto coupling that fits a 1 3/8 pto shaft. My pto coupling fits a 1 1/8 shaft. I am taking pump off of Allis B and wanting to put it on a Allis WC. If anyone has any parts email me with tele# or call me at 1-573-470-2573. Thanks Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 4:37pm
Your local Farm and Fleet or Tractor Supply store will have an adapter that fits the     1 1/8 and has an 1 3/8 spline on the back.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 6:32pm
Here's the way someone mounted one on an unstyled WC. There's a shaft inside that pipe that's visible in the picture, there's a pair of Vicegrips clamped to the pipe to keep it from turning. The shaft is driven by a V-belt off the front of the crank shaft, then a roller chain drives the pump. If you look hard you can see the chain and sprocket. A little but it gives you live hydraulics.
Dusty
