D17 FRONT TIRE SIZE
jeickman01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeickman01 Quote  Post ReplyReply Direct Link To This Post Topic: D17 FRONT TIRE SIZE
    Posted: 18 Aug 2017 at 6:50pm
Did not realize that tire sizing was next to rocket science.  New 6 x 16 rims, 6 lug D17 rims are on their way and I need to find tires to match.  If I understand tire sizing correctly, a 6 X 16 rim is 6 inches wide at the bead and will take a wider than 6 inch tire.  A 6 x 16 inch tire is 6 inches wide from sidewall to sidewall, not bead to bead.  Armed with this understanding nothing makes sense searching the net for tires.  Yes, I should rely on the brick and mortar tire dealer where my retirement tractor is located but I need to have everything in hand and mounted before my next trip.  Any suggestions for a lower compaction tire for a D17 that will support a front end loader.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2017 at 7:24pm
600 or 650x16 should work an look good also. a tire to fat will look dum?
ksbowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2017 at 7:43pm
My 170d had 7.50 x 16 on it when I got it 25 years ago and I assumed those came on it. When I replaced them that is what I put back on and they look correct.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2017 at 8:45pm
My series 4 had 650x16"s on it when I got it. I put 750X16's on it. They look good on it.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2017 at 8:58pm
6.50-16 or 750-16 will be fine on your rims. Pending funds I would go with the 7.50s.
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2017 at 8:59pm
Just put new firestone 7.5s they look very good.
Edited by Josh Day - 18 Aug 2017 at 9:00pm
AC's 75' 7040, 64' D-17S4, 55'WD-45, 54' WD-45, 53' WD-45, 53' WD, 52' CA, 36' WC. IH 656. Deere's 38' A, and 47' A
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2017 at 9:15pm
Both of my Series IVs have 7.5 x 16 on them.  I would not go any smaller.
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2017 at 7:33am
I have 7.5  x  16 four rib tractor front tires. Looks good and they have held up to loader work just fine.
