fluid removal |
Post Reply ![]() |
iowaman ![]() Bronze Level ![]() ![]() Joined: 06 Jun 2016 Location: iowa Points: 73 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Aug 2017 at 9:46am |
What's the best way to remove fluid from tires other than paying a tire store to do it?
You only live once. But if you live right once is enough.
MNLonnie ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
Roll the tire so the valve stem is on the bottom and unscrew the stem. Just don't stand in front of it or do it inside your shop.
I would like to capture it so I can dispose of it properly.
Dennis(IA) ![]() Silver Level ![]() ![]() Joined: 12 Sep 2009 Location: IOWA Points: 364 |
The tire shop did not charge me because they kept the fluid.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
You can buy a piece of clear plastic hose at a good hardware store. I had the tire on my flatbed and set a 5 gallon bucket under it. switch out buckets as they fill and dump into a larger container.
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4745 |
That is one problem we don't have as we put straight water in out here.
I thought it was salt the same as spread on your roads to keep ice from forming. But several ways I can think of to catch the solution,clamp a small hose to valve stem after removing the valve then roll tire so stem is on the bottom. Us a little diaphragm pump like in RV or spot sprayers. Seems like a lot of work to be politically correct. Or is there more than calcium chloride in that stuff???
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
Most tire shops will come and get it if you let them keep it.
JW in MO ![]() Orange Level ![]() ![]() Joined: 16 Feb 2010 Location: South KC Area Points: 2666 |
I picked up over 100 gallon in a couple days by advertising on Craigslist. I offered to take it out for the CACL, only one guy wanted me to pay him for it and drive 50 miles, he prolly didn't do what I suggested before I hung up. I would put it on craigslist in Farm Equipment, someone might want it.
TimNearFortWorth ![]() Orange Level ![]() ![]() Joined: 12 Dec 2009 Points: 2014 |
LMAO at that one JW, made my night when I read it.
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
one farm tire store will buy it from me at 1/2 the cost of retail, and they will pump it out.
grinder220 ![]() Orange Level ![]() Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2372 |
I rigged up my own little contraption to remove fluid by taking a T-fitting and putting a 3/8 nipple on one end and a valve with a nipple on the other end and a valve stem in the middle. Connect a short hose to the side without the vale and put a piece of 1/4 inch copper tubing about 18 inches long with a compression fitting collar into the hose 3 inches or so and clamp it with a hose clamp. The copper tube will fit in the tube after you remove the valve stem and the hose will snuggly fit over the threaded part of the tube,put another hose clamp on that also. Then use a long hose for the other end and put it in a container large enough to hold the fluid, I use 275 gallon bulk tanks I get from work. Close the valve and hook up the air to pressurize the tire,unhook the air and open the valve and the pressure forces the fluid into the tank. Repeat until empty. Its a little slow process but it works and if you do it right with the copper tube lenght inside the tube it will get all the fluid out. Take about an hour to empty an 18.4 34 tire. PS,tire is jacked up and valve stem at 12 o'clock when hooking this up ,6 o'clock to empty. I've done several different sized tires this way.
Its impossible to post proper sized pictures on here from my phone.
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
You do realize its the same stuff they use to control dust on a gravel road don't you? If you live on a gravel road lightly sprinkle the road. |
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3927 |
That's a good set up there Grinder. I bought the adapter to attach to a washing machine hose and used a 12 volt pump from HF to drain into plastic barrels then back into the tires later.
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8720 |
Years ago, I had calcium chloride removed from the rear tires of several of my little old tractors. The tire shop removed it and put in new tubes in exchange for letting them keep the fluid. Didn't cost me anything more than just getting the tractor to them. Darrel
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4092 |
I emptied several WD tires using gravity and a shop vac. Gave the liquid to my uncle for dust control. The shop vac did a good job of getting all the liquid out.
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
You know unless you remove the tubes theres still a couple gallons in there. I took mine to the tire store they pumped it out kept the fluid put the new tubes in and charged me for just the cost of the tubes. I was happy.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8357 |
Ipulled the valve stem ONCE on a 220,, water shot 30 feet as it came out ! Wasn't thinking that day at all ! Now I used the hose method, a lot better
Edited by DougG - 21 Aug 2017 at 12:47pm |
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5238 |
I also drain mine into a similar tank so I can reuse the apparent water/antifreeze fluid mix that has a greenish tent. I pult my tractor on top of a bank about 10 ft tall. The stem up top, connected the garden hose conversion kit from local NAPA store. Put the other end in the 350 gal tank, and then moved the tractor so the stem is on the bottom. Have a air hose close by to refill the tire after fluid drains out. There will be several gals left in the tube if you dont suck it out. But this allows me to get into a lower weight class to pull and then I refill for farm use. Similar method as above post.
Ranse ![]() Orange Level ![]() ![]() Joined: 11 Mar 2016 Location: Tennessee Points: 775 |
I rolled my wheel into a patch of weeds I wanted to kill and let it go. The only problem is the weeds are still alive and well.
Post Reply ![]() |
