1982 Allis Chalmers tractor hydraulic fluid fill |
JamesTc
Topic: 1982 Allis Chalmers tractor hydraulic fluid fillPosted: 15 Aug 2017 at 8:05pm |
Yes I have a 1982 Allis Chalmers tractor my 3 point hitch won't lift anymore and I believe all the fluid has leaked out of the rear end. Does anyone know where to fill it at and if anyone is familiar with this please help
den/southern illinoi
Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2080 |
Posted: 15 Aug 2017 at 8:07pm |
It would hwelp if we had an idea which tractor model it is. Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor. |
rustydollar
Posted: 19 Aug 2017 at 7:22pm |
Your problem is not model specific, the trans-axle is also the hydraulic oil reservoir, look under the seat for a pipe plug. A 9/16th " open end will remove the plug, once you have the plug in your hand you'll notice a dip stick has been affixed to the underside. Use a small funnel to add oil through the open hole from which the pipe plug has been removed. Careful not to over fill. Edited by rustydollar - 19 Aug 2017 at 7:24pm |
