D17 transmission
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Topic: D17 transmission
    Posted: 15 Aug 2017 at 11:20am
The series IV D17 that I bought got engaged in two gears at once when I tried for reverse. Removed the trans cover and lined up everything in neutral. Put it back together and it seemed to work alright. It makes a loud clunking noise in second gear. Had cover off again. Bottom of shifter and rails and forks all look good to me. I think that I have everything aligned properly when I put the cover back on. Any ideas would be appreciated.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 8:03pm
Mine made a tapping noise, input bearing was bad.
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 8:17pm
Not knowing the abuse, may have broke a tooth off on 2nd gear.  I never had the top off a D17 transmission, but you should be able to remove the top and jack one wheel up and roll the gears around and inspect them.
