HD5B Undercarriage Rebuild
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: HD5B Undercarriage Rebuild
    Posted: 12 Aug 2017 at 9:38am
I have a few questions about parts. Since it's difficult to find parts for this old machine could the undercarriage be updated to a newer style from a different brand?
Could the undercarriage be retro fitted with newer parts from other brands?
Edited by DennisA (IL) - 12 Aug 2017 at 9:14pm
Thanks & God Bless
Dennis
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 5:55pm
The HD5 and HD6 use same parts for undercarriage,stering cluch,transmission and final drive and have some used parts for
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2017 at 8:45am
I've always felt that a man good with a torch and welder can do anything.
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2017 at 11:40am
We have a complete Hd-5 with good sprockets and tracks For Sale If interested send me a message Unit has a bad engine.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2017 at 4:21pm
HD-5B is a dozer, correct? will a 2-71 overhaul fix the engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2017 at 7:10pm
Hd-5b correct. It is a loader And yes engine would have to be gone through completely ran when we got it it is stuck now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2017 at 8:27am
Some IH track had about same pitch as AC track - but again that's a old machine so more than likely just made of the same material impossibly unobrainium .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2017 at 9:17pm
Will be 6.5" pitch as noted only IH or Dresser used that much as the 7.0 on my own Allis. Nothing comes to mind close which leaves sprocket splicing to use Cat, Case or Deere rails then convert the rollers on the bottom of the truck and possibly morph a idler to fit the mounts. Daunting while expensive but not impossible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2017 at 11:12pm
I have a 2-71 setting out back from a machine i bought - said had no oil pressure - I never looked further into the engine or even how good it is - I am unsure of what else or anything is wrong with it - would part with it as a core engine .
 Also a Perkins 6 cylinder with turbo - was in a Suburban - with a 4 speed behind it  that is also up for sale
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 9:05am
Someone needs to hook up with a chinese company to reproduce UC parts for these machines.  While I agree that name brand top quality UC parts or chain would be ideal,  it would be too costly and for no more than what a lot of these old machines run, they could keep them going along time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 10:03am
believe there are [arts there from China for them - but no one is importing them as cost prohibitive in small numbers that would be sold .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 11:09am
Was told that by a distributor from TX. They can get but the minimal order is enough to build 1000 sets for my machine or the HD11/11B series, the special order would languish in their stores room and cost them in inventory taxes they would not recover so won't do it.
This page was generated in 0.136 seconds.
