48 allis Chalmers c broken valve spring
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Topic: 48 allis Chalmers c broken valve spring
    Posted: 11 Aug 2017 at 1:24pm
Was wondering if anyone on here has had this happen to them. How much of a job is it to replace the spring. Probably should buy a set of springs and have the valves ground. Any tips would be helpful. I'm not looking to spend a lot of money on it. That being said I want it done right so if I have to I'll keep it shedded until I can afford the parts. Thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 1:51pm
To simply replace one spring isn't too bad. Remove the spark plug to the cylinder affected. With the piston near the bottom, shove about 8 feet of 5/16" nylon rope down into the cylinder. Turn engine over by hand until the coiled up rope is holding both valves up tight and remove rocker arm shaft. There is a valve spring compressor from Craftsman (and others) to compress the spring and remove the retainers. Have fun.
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 1:53pm
Alright thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 7:21am
Do it cheap or do it right, you can't do both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 7:51am
X2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 7:58am
Take an old spark plug and break off all the ceramic.  Now take an air hose connector and glue (JB Weld Steel) or braze/weld this to the metal threads of the spark plug.  Insert the new tool and plug the air hose to it.  This will hold the valve up while you do the work.  You don't have to worry about bending a valve this way.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 12:51pm
Whoah, what is wrong with just fixing what is broke?  Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 6:18am
I was reminded that you should ALSO have the piston at the top of the compression stroke when you put the spark plug/air plug onto the head.  The reason is so that if you lose air pressure or unhook the air hose, the valve doesn't fall inside the cylinder. Dead Dead
Thanks orangeborn.......somebody would have been cussing me!!  Sometimes we take things for granted Clap and/or assume.........ass/u/me...Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 7:04am
I would be willing to bet, you aren't far from other springs failing. I would also bet, the guides aren't in great shape and seats are worn too
 When I had the head off my 45 to clean up the manifold area after a long time of leaking, I ended up replacing the guides, springs and valves. It made the thing run like a new one too. I only had to buy parts, and did the work myself, so it didn't cost me much and was well worth my time
 On the other hand, replacing one spring without removing the head would be way cheaper.
Rog(NCWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog(NCWI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2017 at 8:52pm
Do it right. Take it in to a repair shop and have them rebuild it for you. I can bet that there will be other springs reedy to brake. Give it a valve job and put a new head gasket in it to. Cheaper in the long run.
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 6:42am
Thank you for all of the suggestions. I think I may let it sit until I can buy the parts to rebuild the head. This tractor is the first I bought when I was 18 so I have a sentimental attachment to it. It's also a wide front which is neat because they're more rare.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 7:09am
Stick a valve spring on get it back to work then this winter pull the head and have it completly rebuilt then wwhile the head is off you can chek for sleve wear and maybeee take a look at the bearings and have the time to dig deeper or just over haul the whole thing and hopefully never have to worry about the motor
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 7:55am
Good suggestion Brad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 8:10am
Good idea, but i would do like Richard Rawlings always says, let her rip tader chip.  Wink
