1979, 185 shifting problems
oscar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oscar Quote  Post ReplyReply Direct Link To This Post Topic: 1979, 185 shifting problems
    Posted: 09 Aug 2017 at 9:07am
I backed up to unhook my tractor from a trailer. Unhooked it and then I cannot shift into any gear forward or reverse. I can feet it shift into the gear but it does not move. Any help will be appreciated!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 9:14am
Do you have power steering ????????
Post Options Post Options   Thanks (0) Thanks(0)   Quote oscar Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 9:15am
Yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 10:10am
Foot clutch center has failed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oscar Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 10:19am
Thanks for the help, I am pretty good at fixing things is this a big job? Are there any resources on how to do this job?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 11:44am
If the foot clutch has failed, the PTO will not pull a load either. Shift into any gear with Power Director lever in low or high and the PTO should NOT turn if the foot clutch is the problem. I take it the gearshift feels OK, the tractor just won't move ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote oscar Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 12:27pm
The PTO Turns fine, It does not have a load on the PTO, but it starts turning the second you engage it. Thanks again for helping me, I know everyone's time is valuable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 1:38pm
Just an opinion, but if the foot clutch was out the gears would grind horrible , he says it will go into gear
Post Options Post Options   Thanks (0) Thanks(0)   Quote oscar Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 1:43pm
No grinding unless you go to reverse. Feels like it goes in the other gears fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 3:37pm
If the PTO works, the foot clutch is fine. Seems funny the way you describe it. I'm not there. I give up.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 4:14pm
Maybe a problem in the final drives or a broken axle?
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 8:59pm
On the early model 185 we have had same type of issues at 10 degrees or colder-- tractor will shift into gear, not move. PTO & steering work fine, not sure about the director because no forward or reverse movement. Allow to run for about 10 min and everything is fine- and has been that way for several years. Tractor has high hours -- I always thought the shifter may not allow to fully catch the gear when very cold due to wear. Feels like it's in gear though. Maybe the same type of an issue?? This one to date still operates fine under normal conditions.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 6:30am
To me it sounds like the valve for the power director is stuck in neutral position. Just a guess on my part.
Wink
I am a Russian Bot
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 6:37am
Did you move the power director while unhooking the trailer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 7:30am
Spider gear pin fell out.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote oscar Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 8:34am
Did not move the power director, Let it run for a long time to warm it up to see if it would move. How hard is it to check the power director and the spider gear pin?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 8:37am
If the differential spider pin fell out, you'd be able to grind ALL GEARS with engine running and clutch pedal up and Power Director lever in low or high.
