Allis C Rear Axle Lube |
Post Reply ![]() |
Jim-Ohio ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Cols.Grove,Ohio Points: 335 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Aug 2017 at 12:42pm |
In regards to the long axle shaft that runs through the top of the axle housing from the rear end to the top of the bull gear , how do the bearings on each end of the shaft get any lubrication?
'61D17, '51WD, '51CA, '41C, '49C, Woods 5'&6'Mower, 6'Blade, CA-Plow, CA-Cultivator, 3-Btm snap-coupler plow, 4-row planter, WD 4-row cultivator, 80R mower,#7 mower,B/C mower
Leon n/c AR. ![]() Bronze Level ![]() ![]() Joined: 19 Mar 2013 Location: Heber Springs A Points: 175 |
The only lube that bearing gets is from the excess from the small gear and what might be slung off the bull gear. Leon
Post Reply ![]() |
