WC rear hub oil seal
drak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drak Quote  Post ReplyReply Direct Link To This Post Topic: WC rear hub oil seal
    Posted: 01 Aug 2017 at 2:58pm
Does any one have the dimensions of the rear hub oil seals for a WC ?
I need to purchase two but don't want to strip her down till I have the  seals in hand, I know I can purchase from the US but customs charge an arm and a leg and it takes forever to arrive across the pond.
I have checked all the manuals I have but can't find mention of sizes !!!
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2017 at 4:08pm
dont have a number but found this
Product Details: Rear Axle Hub Rubber Oil Seal
Applications and Uses:
RC, WC, WF, W Speed patrol
Notes: 2 used per tractor; Sold individually
Specifications: 0.795" wide, 9.975" O.D., 8.550" I.D.
OEM Replacement Part Numbers: U2533, 70202533, 79016729
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2017 at 9:26pm
I sell new cork seals like the original. they will not squeak like the rubber seals. can ship to the UK.
drak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drak Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 1:35am
Thanks for your follow up much appreciated, I seen these measurements also on DJS web site but they don't make any sense to me ? I hazard a guess that the pinion shaft is no more than 2" in diameter !!!
My problem is oil is leaking from the diff and running down the tyres telling me its the pinion shaft oil seals need replacing, I am guessing the seal dimensions you suggest go somewhere else ??
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 3:50am
The seal goes on the outside of the hub.
See the picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 7:56am
you need the inner pinion seal then not the final drive seal.
agco # is 70202602
crosses to skf #19407
Stock Number 19407
Description LDS & SMALL BORE SEAL
Lip Code Nitrile (Lip Code: R)
Type/Style CRW1
Inches Shaft 1.938
Bore 3.189
OD 3.194
Width 0.313
Weight 0.125
parts book also shows some kinda of inner seal that is different on steel rear end models.  im guessing this was a 2 piece seal and the former has replaced it
Edited by CAL(KS) - 02 Aug 2017 at 8:03am
drak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drak Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 12:45pm
Thanks Carl
Yes I noticed after I messaged you today that I had made a big mistake by saying hub seal.
Anyway we got there in the end, many thanks for the dimensions hopefully now I can order the seals !! how does one remove and replace the inner one ? is it through the top of the brake casting ? I am sure all will become clear once I strip her down !!
drak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drak Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 12:48pm
Thanks Garry, I was not even aware there was a seal there, deft not one there now !!
I am guessing its to stop dirt etc from getting in  rather than oil out ???
Dave Everett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 8:54am
ring Mark at ATS Tyres salisbury 01722 336789  we can order the parts from AGCO
part no 70202502 we have done many on WCs and WFs inner and outer seals
Why?
wd45tim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wd45tim Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2019 at 3:39pm
Do you still sell cork wc hub seals? I was reading the posts and saw your
reply and thought i may as well ask. Thankyou wd45tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2019 at 5:06pm
I think we have 202602 seal
Pfouts Family Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pfouts Family Farm Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 5:21am
Tim,
Yes we still handle the cork hub seals. We took over Norm's business about a year ago. If you need these seals or any other parts, give us a call or email
(330)569-7037
pfoutsfamilyfarm@gmail.com
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 8:48am
Is the same seal used on both sides of the brake chamber on the pinion shaft on a WC?
oldways View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 11:01pm
National oil seal part # 450094 is the same as agco 70202602 . Also a Dodge truck (late 90's early 2000 maybe) wheel seal. Most auto parts will have them or can order. I replaced mine last winter and discovered this. The national seals actually fit better than the agco did on my wc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 11:06pm
Takes 4 on s# 86405 and prior. Only 2 after s#86405. According to the parts manual.
