Allis Chalmers c rusty gas tank
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers c rusty gas tank
    Posted: 29 Jul 2017 at 7:15pm
So I'd like to hear any sound advice from anyone on here that has been able to remove as much rust from inside the tank as possible. Any cool tricks would be great
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 10:02pm
I've posted the same question before myself. I got a lot of good advice, and tried about all of it except filling it with rocks and strapping it to a back wheel and driving around. I was afraid it would fall off and I would run over it with my luck. I usually use a short piece of log chain to shake around in it. If you got a way to rotate it would be even better. Then I fill it with water and put a pint of muriatic acid and sit over night. Then rinse it out good with acetone. The problem is, the rust is like a cancer. It keeps coming back. I put that blue coat stuff in my B tank and put a one inch stand pipe in it. I hadn't had much problems since then, but I've been told that coating will turn to goo after a while.
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 12:10am
I just finished cleaning a wd tank using electrolysis. I'm very pleased with the results!
Ben
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 6:12am
Ben, did you put a rod down inside or what?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 7:44am
I'd like to know more about that electrolysis myself. What is it, and how is it done?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 9:07am
Some Radiator shops service and clean fuel tanks. You might want to check in your town to see if the local Radiator shop offers that service. If they do, its well worth the money to have it tanked out, sealed and any repairs done. No messin' with acids, chains, and whatever. You get back the cleanest tank possible and they usually seal it for you to! Around here, they charge $100.-$150. bucks. Well worth it in my opinion...
Steve@B&B
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 9:16am
Steve@B&B
X2 Steve!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 9:30am
http://antique-engines.com/electrol.asp
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 3:02pm
Yes I did put a rod down inside. Used a piece of rebar. I put a funnel in the neck of the tank to act as an insulator to keep the rebar anode from shorting to the tank. Clipped negative lead to tank, positive lead to rebar anode. Filled with water and washing soda solution. Used 1 tablespoon per gallon of water.
This page was generated in 0.945 seconds.
