Electrolysis tutorial |
Page 12> |
littlemarv
Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
Topic: Electrolysis tutorialPosted: 23 Jul 2017 at 10:32pm |
I'm going to try to clean the inside of the gas tank on my WC with electrolysis. Someone explained it to me briefly but I forgot what you put in with the water.
My plan is to: Put a brass pipe plug in the bottom of the tank, and attach the negative lead of my trickle charger to that. Then, stick the sacrificial rod in through the filler neck, and insulate it so it doesn't touch the tank. Clip the red lead on there, and change the solution every day? So, I guess my questions are, does that sound right, and how much of what do I mix in with the water? I think the tank is 15 gallons. Thanks in advance.
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
Dipstick In
Joined: 11 Sep 2009 Location: Remington, In. Points: 8602 |
Posted: 24 Jul 2017 at 12:50am |
Washing soda is what you want and you can find it in the soap section of many of the grocery stores, including Wallworld. I'm gonna guess a cup or two in fifteen gallons of water,,,,,,,, and as far as draining/changing, I think I would just "float" the gunk and crap off, and keep charging it.
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4942 |
Posted: 24 Jul 2017 at 6:09am |
One tablespoon washing soda per gallon, check and clean anode as needed to keep reaction going
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25270 |
Posted: 24 Jul 2017 at 6:18am |
the big problem is that the closest tank area will get cleaned. Think 'line of sight', 'shortest distance'. You'll have to get 'creative' to locate the sacrificail rod to get all of the tank. Also be sure it's secure ! You don't want it to 'wiggle' loose overnight.
It'll be a bit of a pain cause you have to disassemble it, drain it to see how you're doing but it should work.... Please post pictures if you can... |
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3132 |
Posted: 24 Jul 2017 at 7:07am |
Even through the closest areas will clean first, all other areas will still clean. Just a little slower. should be easy since there are no baffles. I clean a 110 gallon transfer tank the same way a couple years ago!
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5191 |
Posted: 24 Jul 2017 at 7:47am |
I use this link as my guide. I've tried both solutions and I seem to have better luck using lye.
As far as changing the solution, I've "strained" mine (through an old towel) a few times, but I've been using the same solution for about 3 years.
Edited by WF owner - 24 Jul 2017 at 7:50am |
littlemarv
Posted: 24 Jul 2017 at 8:55am |
Thanks for the info. I planned on making a few "L" shaped rods to get to both ends a little better.
Just like last year, going to Hutch and drooling over all those perfect tractors gives me the kick in the pants I needed. Time to finish up the WC! Just need to change the big seals on the rear wheels, clean out the tank, and once (if) we get some weather where it stays above 60° at night, up goes the portable paint booth! |
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3609 |
Posted: 24 Jul 2017 at 9:14am |
Lye and that washing powder is darn near impossible to find in these parts.
Not to fret though. Took me 10 years to learn this but the swimming pool stuff, think is was called sodium carbonate, worked better than anything for me. I think the key is adding enough stuff until you are satisfied with the electrical flow as evidenced by bubbles produced. I also think that Rip VanWinkle will wake up before that "trickle charger" gets the job done. I always hooked my stuff up to a 10 amp smart charger and added enough stuff to get the charge up to around 6 amps. Maybe you would want less on your tank. have fun. |
WF owner
Posted: 24 Jul 2017 at 10:06am |
I was able to find Lye at y local True Value hardware store. (No luck at Lowes or Home Depot.)
I just found this at Amazon.com
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 24 Jul 2017 at 10:52am |
Have done two WD gas tanks this way. I find Arm and Hammer Washing soda at Walmart. Bottom shelf stuff, not in high demand. I would probable use 1/2 cup inside a gas tank filled with water. I like this stuff because its safe.
I use a heavy duty battery charger set at 2 amp. Its hooked to a 12 volt battery and then another set of leads with clips to the cleaning item. I had my gas tanks submerged and cleaned the outside at the same time.:) I think I used a piece of 3/4 dia steel rod suspended inside and insulated from the tank. I have parts cleaning in the E-tank now for the 1952 IH TD6 dozer project. Regards, Chris Edited by Sugarmaker - 24 Jul 2017 at 10:53am |
littlemarv
Posted: 24 Jul 2017 at 1:32pm |
All I have is a trickle charger- I thought that's what you used. Is that not enough?
DrAllis
Posted: 24 Jul 2017 at 3:37pm |
Sand blast and power wash it out afterwards. Done several that way with excellent results.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90845 |
Posted: 24 Jul 2017 at 3:46pm |
a trickle charger is less than an amp... that would take a month of soaking.. Your better off with a 10 amp charger that will put out 4-6 amps constant.......... for the sacrificial rod, more surface area is better... sometimes a 1 inch strap 1/4 inch thick is better than a 1/2 inch rod.
Roscoe62
Joined: 22 Aug 2014 Location: Louisville Points: 145 |
Posted: 26 Jul 2017 at 5:02am |
Ditto on the 6 amp charger.
And as someone mentioned above, if the charger is one of those new "smart" (aka dumb) chargers, you must put a battery in parallel, or the smart charger will not put out any current!
- Roscoe |
littlemarv
Posted: 22 Aug 2017 at 9:42pm |
O.K, here we go. Made a sacrificial rod out of a mudflap hanger, wrapped in an inner tube and piece of silicone hose to insulate it from the tank, and gently inserted into the receiver hitch of my truck and jumped up and down on until it is precisely the right shape for maximum cleaning action (or something like that)
![]() I figure I will do each end of the tank for a day or two, then put the rod straight down for a day or two. ![]() ![]() Dumped in two cups of washing soda and filled it with water. ![]() ![]() Hooked up my jumper cables, neg to the pipe plug in the bottom of the tank, pos to the rod, put a battery inbetween the tank and charger. Set the charger on 30 amps as that's as low as it goes. Seems to settle in at a little less than 10 amps. ![]() I guess in the back of my mind, I thought the water would start boiling and crap would come flying out as soon as I hooked it up, but I guess its not that quick. After a half hour, the crud started showing up. ![]() After a couple hours, really started looking yucky in there... ![]() So, how do I keep this going? Do I keep adding water? Do I change the solution daily, or shove the hose in the tank and flush it out the top till it runs clear, or drain and rinse, I don't know. |
JoeM(GA)
Posted: 22 Aug 2017 at 10:02pm |
when the bubbling slows, remove and clean your anode and put it back in. Honestly, with a tank like these I wouldn't even bother moving the anode around unless you just want to. There are no baffles to block the line of site, so it will all get reached in the end. I use the same fluid for several months. Just pour it out into a bucket if you want to look at the progress and then pour it right back in.
steve(ill)
Posted: 22 Aug 2017 at 10:10pm |
I remove the rod every day and scrap off the built up crud on the rod so you can see the steel again......... add a quart of water to flush the floating crud out the top........ reinstall the rod and go another day..
Jacob (WI,ND)
Joined: 11 Sep 2009 Location: Kenmare, ND Points: 1249 |
Posted: 22 Aug 2017 at 10:16pm |
So what is the trick to do a tank with baffles then?
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45 |
JoeM(GA)
Posted: 22 Aug 2017 at 10:47pm |
then you get to bend your anode into what ever shape will get you a line of site to all surfaces without touching the tank wall, might take a couple of moves of the anode to get it all satisfactorily. |
Sugarmaker
Posted: 23 Aug 2017 at 12:25pm |
Looks like a nice set up for your tank. When done (my guess would be several days) Then drain and rinse the inside of the tank the best you can. If you could scrub the inside of the tank that would be great too. Maybe rolling the tank with objects in it could work too.
Rinse again and you should be good to go. Regards, Chris |
littlemarv
Posted: 23 Aug 2017 at 3:16pm |
So here it is after about 20 hours.
![]() I am starting to grasp how this process works. I thought the junk would be floating it the water and you needed to change it to keep it working. But the crud is attached to the rod, so you can just scrape it and keep going. So I scraped and sanded the rod back to bare metal, flushed a little water out the top of the tank, dumped in a snort of washing soda to make up for some being flushed out, and let it go again. So that's why someone up above said more surface area is better. More surface for the crud to attach itself to. Unfortunately, I am limited by the size of the filler neck. Unfortunately, I think pulling the rod tight to hold it is exposing the reason there is epoxy around the filler neck...... something else to fix. ![]() My current plan is, another day on this side of the tank, then tomorrow night change the water and flip the tank around, two days of that, then on Sunday just put the rod straight down into the tank and one day of that. We will see.
littlemarv
Posted: 23 Aug 2017 at 4:28pm |
So if the crud collects on the rod, can I speed up the process by cleaning the rod more often?
steve(ill)
Posted: 23 Aug 2017 at 4:34pm |
that might help a little... as the rod gets coated with crud, you should see the amp gauge drop off.. Your gauge is BIG... I have one that goes to 12 amps... it cleans at 8 amps. When the power drops off to 5 amps its time to clean the rod.
Sugarmaker
Posted: 24 Aug 2017 at 8:05am |
Not sure that you will get any improvement by doing the other side of the tank? This rod should be cleaning the entire inside. It wont hurt to try to move the rod to another position. The process will try to keep cleaning. And we all know that some of these tanks can be really rusty inside. Looks like your gathering a lot of crud, so its working pretty well.
Regards, Chris |
littlemarv
Posted: 24 Aug 2017 at 3:38pm |
Another days worth of nastiness.
![]() Time to drain, rinse, and flip the tank around. I see what you guys mean about just skimming the crud off the top, most of the water in the tank came out clean. Oh well, I only have a couple bucks in the washing soda. Hmmmmm, I wonder if the wand for spraying out the black tank on the camper will fit in the tank? That would work sweet. ![]() Oh heck yeah. ![]() Before ![]() Now ![]() Quite a difference! So, I sanded the rod again and spun the tank around. Filled it back up, and let her go again. I think I will patch the crack on the filler neck, and try and clean the filler neck out as well, as long as I'm at it. It does eat up the rod a little. ![]() I am pretty much sold on this process. It is really neat, and cheap! |
Sugarmaker
Posted: 24 Aug 2017 at 4:28pm |
marv,
It will eventually eat the rod up as you mentioned. (would take a long time. The steel plates I took out of my tank fell apart and what didn't looked like Swiss cheese! Your doing good. I like the fact that it works when I am doing something else too. Now you will need to build a E-tank for doing the exterior of items too. The inside of the gas tank looks better and using the camper nozzle is a great idea. Regards, Chris |
JoeM(GA)
Posted: 24 Aug 2017 at 5:50pm |
Marv, I used wood wedges on both sides of my bar to keep it in the middle of the neck, might not work with a bar as heavy as that flap bracket
littlemarv
Posted: 25 Aug 2017 at 2:50pm |
So, on day 3, there is more gunk on the rod than ever.
How do I know when this process is "done"? Do you go by the cleanliness of the rod? I was just going to run it through Sunday and call it good, the portion I can see sure looks good, but there is still a lot of crud coming out, probably from the top of the tank, where all the condensation hangs? |
JoeM(GA)
Posted: 25 Aug 2017 at 4:36pm |
Marv, you just have to judge from the looks and I usually consider that when I get little to no reaction i.e. Bubbles etc
When the cleaned rod is put back in that it's done all it's gonna do |
Sugarmaker
Posted: 25 Aug 2017 at 8:44pm |
I would say from a time stand point that you should be done. I have cleaned some parts 4 hours and they are good. Other parts 24 to 36 hrs. Not much over that. The cleaned surface gets a black soot on it. The inside of the tank will be hard to get that off. On exterior parts I usually wire brush and rinse and brush some more and rinse. You may only be able to rinse unless you use some type of media inside that you can remove?
Regards, Chris |
Page 12> |
