Allis G hydraulic pump
Charles (KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles (KY) Quote  Post ReplyReply Direct Link To This Post Topic: Allis G hydraulic pump
    Posted: 18 Jun 2010 at 6:15pm
I am in the need of the housing for a G hydraulic pump.  Mine has the top two mounting holes broken off.  Any help is appreciated.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 6:23pm
Hydraulics on a G are not usually parted with at a reasonable price. What's the chance of drilling out the busted bolts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 6:48pm
The ears with the holes in them are broken off.  The bolts came out easily.  I was trying to get away from having to weld the pieces back.  I do have all the pieces but am not much into welding cast.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 7:17pm
  maybe can help   1-574-342-4545 have some parts   need a description?????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 8:22pm
The part in the parts manual is Housing Assy part number 800721 or 800801.  I'll have to look at the pump and see if it has a serial number.  The first number is for one without a serial number and the second number is for one with a serial number.
