AC 616-620 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 616-620 ?
    Posted: 20 Jul 2017 at 5:19pm
Are the flywheels on the CCKA and CCKB used on the 616-620 the same. I was wondering if they would work on either tractors charging system. Thanks Tracy
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2017 at 5:55am
they are different and even with the ccka's there are differences.  There are steel and aluminum flywheels out there
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2017 at 12:16pm
charging systems are also differant and some cckb generator engines do not have a ring gear or starter they motor the gen to start it,  i know this  because we got one running for a guy about a month ago 6500 watt 1800 rpm in a motor home , real heavey gen for a motor home by todays standards
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2017 at 12:19am
I was asking would a flywheel work with either charging system. I know one is a 15 amp and the other was a 20 amp. Is there a difference in the magnets? Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2017 at 7:53pm
Stator is different. Not sure on the flywheels. Couple different kinds on these crazy Onans.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2017 at 9:02pm
Would the 20 amp stator, be too much for the 15 amp harness? Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 8:35am
A 15 amp Stator is to much for a 15 amp harness!  LOL!  Those OEM harnesses are borderline to say the least. You could probably use the 20 amp stator I would think. Just change the fuse or circuit breaker to 20 amp. The engine compartment gets so hot in these particular model Tractors, the wiring takes a beating and gets BBQ'd.
Steve@B&B
