pics from tractor drive earlier this month
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: pics from tractor drive earlier this month
    Posted: 20 Jul 2017 at 8:01am
Have videos too but can't figure out how to post without using youtube or photobucket. I have them in a file on my puter.
Anyhow my 200 and an Oliver 2255 that was sweet and a Deere 8020
couple of the videos from the drive
[TUBE]rCI1F1ZILGM[/TUBE]
[TUBE]8mie5TNmPAA[/TUBE]
Edited by Lonn - 20 Jul 2017 at 2:58pm
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2017 at 8:20am
Great pics Lonn! Thanks for sharin' !!
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2017 at 2:05pm
Suppose they have enough weight on the front of that Oliver to keep it from bouncing going down the road.
Thanks for sharing the pictures.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2017 at 2:54pm
added a couple videos from drive. How can I make the videos look normal...... not so narrow?
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2017 at 9:28pm
Lonn,
Thanks for sharing. Good to see. You must of had a slower ride to get those older 2 cyl JDs...we go 10 mph on ours so 530 JD and some older JD can come. I have not been on a tractor ride this summer yet! Hope to in August.
Mike in Iowa
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2017 at 12:09pm
Once we had a H Deere on the ride....... now that was slow.
Wink
I am a Russian Bot
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2017 at 1:41pm
I gotta say it, that 8020 looks pretty cool.  I'm not sure if I've ever seen one.  Not knowing jack about it's numbers, sure seems it would have been BA for it's day.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2017 at 6:01am
Does the 8020 have an 8V71 engine swap?
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2017 at 11:31pm
Lonn, thanks for sharing great photos & video. Your AC 200 looks like its a low hour tractor? It's in great condition with an original AC factory cab. I enjoyed listening to you talk & your tractor radio song during video.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2017 at 8:39am
I couldn't tell you. I've stood next to that tractor several times in the last several years either at a tractor drive or at our local plow day but I just don't remember what it has under the hood. The owner use to use it in his tiling outfit when I was a kid. I believe it was used on my Dad's farm, the farm I live on today, to tile the ground back in the early 1970's. The owner is quite a nice guy and at one time could build most anything he needed. He built his own tile plow way back then and built an all in one self propelled tile machine he named "lean mean green machine" or something like that. A few years ago he also built a fully mounted 8 bottom plow for this 8020 that looks just like the original 8 bottom Deere built specifically for these tractors.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2017 at 8:41am
Thanks, I should figure out how to make a wider picture video. When I turn my ipod sideways the video is wider but then it is also sideways if I remember right.
Wink
I am a Russian Bot
243Hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 243Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2017 at 3:54am
Calvin those 8020s has the I671 Detroit motor in them
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 9:13am
Nice pictures.  The Oliver is sweet and the 8020 is a cool tractor to look at but if all three were in line Id still spend the most time looking at your 200.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 9:51am
Thanks Jim and everyone else for your comments
Wink
I am a Russian Bot
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 10:13am
Enjoyed the videos and pictures.  Great job!
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 8:54pm
Mecum just sold one of those 8020s in June for $160,000.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 9:46am
I know that the 8020 came from the factory with A 6-71 Detroit but by the picture it seems obvious that there is a 8V71 under the hood now.  318 hp should pull the drainage plow.
Would be a bolt in conversion.  There is a local 5020 with a Kinze 8V71 conversion that been around for as long as I remember.
